Recommendations repairing hydraulic cylinder trunnion
jovol
L48 TLB, New holland LS180, Woodmizer LT50
Jan 2, 2020
36
Lake Lure
Hey, I have an L48 and the backhoe swing cylinders need some repairs. The trunnions on them are supposed to be 1-3/4" OD, they're closer to 1.65" now (not consistent either). Would it be possible for a machine shop to weld them back up and machine them back to spec? I'm not familiar with trying to fixture something like this, or the tool required to do the machining.
Thanks for any advice.
John
9,139
Those are going to be tough to work with.
I think that's the best option
Keep in mind the case for that cylinder is available for about 1K. 😲
5,179
John
Why not ask a machine shop if they can cut the pins flush, bore out to required size, and machine proper sized pin stock to weld (or cross pin) in?
7,016
Yeah, I can see how that'd be a challenge.
Not a single through-pin, but two anchored in a collar around the cylinder.
We've got some very good machinists here, but looks like re-building/machining to spec what's there might be best option?
This is a BT1100 backhoe option for L48. Looks like/similar to the photo.
jovol
Jan 2, 2020
36
Lake Lure
Is there a tool for a mill that can machine the OD of the pins? Kind of like a plug cutter. If there is, I imagine welding it up and using that tool would be the way to go. I'm not sure what that tool would be called. If I knew it might make it easier asking machine shops if they have that tool. Or maybe a CNC with a normal endmill can be precise enough. It doesn't seem feasible to chuck the barrel in a lathe using the opposite side pin, 1 because the trunnion is not centered on the barrel so the weight imbalance would be substantial, and 2 the pins aren't true. I'm not sure, maybe a pro machinist would have a different opinion.
@RCW that is the correct parts diagram.
By the case, do you mean the trunnion mount that get's welded to the barrel?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,434
1,728
Kalamazoo, MI
Use a single point boring head in a mill. Do one side, flip it over and do the other. Spin out a couple of bushings and weld them on the pins.
jovol
Jan 2, 2020
36
Lake Lure
Thank you. That turned up this YouTube b vid, which helped me see how it works
9,139
Have you pulled the bushings to make sure you haven't worn them down past being replaceable?
If they are replaceable then your good to go after you resize the cylinder back to size.
If they are not replaceable because it's worn through them, then your looking a lot more work!
Line boring the frame is a huge deal.
5,614
Its just a cylinder trunnion - nothing high precision in terms of the alignment. Restoring the diameter of the pins is the central goal. Weld thwm up and regrind. A decent (i.e. creative) machine shop will figure out a way to swing it for grinding. I can think of a couple possibilities with what I have in my little shop. Probably going to be a bit pricey but not break the bank expensive.
Same for the bores in the frame. Bore oversize and bush back to size.
3,149
I used this method to re-machine the swing pivots on my backhoe.
After cleaning up the damage, it was easy to make oversize bushings for the mating parts.
Here is a thread in which myself and another gentleman shared info on rebuilding our B670 Backhoes.
We both had worn out swing pivots (trunnions) and tackled the problem in different ways.
The pertinent pics are in post #2, #4, #7, #12, #16, #17.
jovol
Jan 2, 2020
36
Lake Lure
Fortunately the boss for the bushings are still good. I’d rather stick to spec sizes so kubota’s greaseable bushings do the job, although I’m sure there are off the shelf ones close in size. The spec bushings are 1-3/4 id, 2-1/8 od, 1-1/4 long.
@Lil Foot thanks I’ll check that out
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
234
75
NE Wyoming
Turning an od in a mill is called trepanning. They can be welded and trepanned in a horizontal boring mill. I've done several over the years, but nothing on one that small. The ones I have done were on mining equipment.
3,914
2,561
I'd price out a new one and delivery timing then get an estimate from your local machine shop to fix yours and how long they'd take to fix it.
If your machine is a money maker then your decision is made for you.
jovol
Jan 2, 2020
36
Lake Lure
Just wanted to round the thread off. A local machinist turned the trunnions on a mill with an outside boring head (exactly like this video on youtube
) and slipped a hardened sleeve over the trunnions with a 2-3 mil interference fit. He did both cylinders for $350, a good bit of savings over replacing both barrels.
9,139
I've watched a ton of his videos.
Just have to downsize for what little things I work on, but really good info!
