M7060HD12 stuck in park
Thunder chicken
M7060
Dec 29, 2019
296
120
Northern ontario
Theres not many complaints on the internet about them it seems. But it doesnt take much adjustment to make it work, or work horrible. I had a issue but it was from some wear/seized bearing (a very small one on one of those moving parts) Then i had a stick flip up and bend some stuff. Once adjusted it it was fine. It took me many small adjustments to get it right.
If you look/watch the movement youll see how it all works. I bet you can get the parking brake off with a few pry bars and being careful.
5,718
in post #13, it looks/sounds like IF the return spring #8 goes MIA, the parking brake can latch on.....
have no idea what's in between the 'knob' and the 'pawl' but anything (like chunks of mud or ice ) might force it into park ?
8,811
I checked that boot, no tears or holes, and I don’t see any bending. I’m thinking the linkage just needs some adjustment. The shifter has always been a pain in the butt.
So it looks like you're on the right track then. No doubt the dealer will address the problem shortly and your M will be up and running in no time.
I'd completely forgotten about the parking brake being up with the gear shift on the M7060 until I looked at the WSM and the 7060/6060 brochure. It must be a nice feature I'm sure when it works properly. I've said this a number of times but had I ordered an M it would have been the 7060, but the 6060 was on the lot and available at a great price so that's the path I chose.
Please keep us posted on the resolution of this issue.
ego260
RTV
Feb 4, 2020
14
Augusta, Wisconsin, USA
In the Oper Man, I see the 12F/12R shifter has a Park position that the 8F/8R doesn't. What does this do?
We also have an 8560 with the feature, but that adjustment seems to be loose. They tractor will literally rock back and forth in park. I hoped up in a M5-111 yesterday, seems they’ve gone away from this system and added a different parking brake
8,811
The M6060 has a simple foot brake lock like the MX. Not an elegant solution but it works. I admit that I use the brake lock on both tractors as little as possible.
ego260
RTV
Feb 4, 2020
14
That’s smart, I always use it, and I think I’m gonna stop and start relying on dropping the FEL and implement when I’m on flat ground.
Also, as an update a service tech came out today and got it going while I was on a plane flying down to Louisiana. The linkage adjustments got way out of whack, they’re adjusted now and everything is working good according to the tech and my grandpa who checked it out.
8,811
That's good to hear! A simple fix and hopefully your gear shift lever moves better than it ever has. (y)
David N
M7060
Jan 6, 2024
26
44
MN
Reviving a year old thread................
So the park break linkage must be an issue for some...........currently my 7060 won't shift outa park either. It did it once last winter too and must have something to do with the cold.....everything being stiff seems to be the culprit. It was -20 ° here last night. I went to fire up the beast this afternoon and I can't move it. I may need to have someone pry on the linkage as I move the shift lever? At least git her to move so I can pull it inside to work on it.
From the looks of it in the manual pages posted, I need to adjust parking brake rod..........
8,811
Do you need a copy of the WSM? It's 48MB in size so most likely too big to email but @North Idaho Wolfman should be able to get you a copy. If not, I can upload to DropBox or similar and PM you a link. I'm fairly sure that @North Idaho Wolfman sent me the copy that I have.
I bought a hard copy WSM for the MX from the local dealer and wish I had a digital (PDF) for that tractor too.
David N
M7060
Jan 6, 2024
26
44
MN
It's definitely a cold weather thing........I pointed the ol torpedo heater at 'er for a bit and she shifted outa park. I still will adjust the linkage though............
