I made sure I was getting good fuel to the injector and that the pull stop switch was not banged up but still no smoke when turning over after 15 seconds. Going to put a fresh battery on it. I am guessing since the engine was completely empty of fluids it is taking time for everything to get back through the system to ignite. With having to disconnect the wire from the starter to jump start the tractor would that be bypassing any switches besides the safeties that would not let the tractor start? Thanks for help
Bill, you have any luck starting yet?
The L35 only has 3 safety switches. And these matter only if you're using the existing wiring:
Won't Start unless:
--Fwd-Rev lever in Neutral
--PTO off
The Brake switch only turns on a dash light - not part of starting.
So if you're bypassing OEM wiring straight to battery so you can get the engine to crank, the only thing preventing starting (other than very broken things) would be:
--No fuel into the injectors (possible air in line)
--LIFT pump not working to supply the injector pump (manipulated by an engine cam - not electrical)
--Injector pump not working - not enough pressure or timing - air in line (turned by an engine cam)
--Fuel lines clogged or other obstruction
--Fuel rack on injector pump in OFF position (check that the key solenoid is disconnected as a test)
Hopefully when the shop put your engine together they didn't leave out any parts.
Just don't use any starting fluid with the machine.
Bleed to see if the lift pump is supplying fuel to the injector pump.
Bleed to see fuel coming out the top of the injector pump
Then bleed at the injectors to see fuel coming out there.
You shouldn't have to crank that long to see the fuel from these places.
Once you know fuel is coming to the injector pump, close that valve.
