L2800 Wiring diagram
2,056
Try kubotabooks dot com and see if they have a manual or work shop manual
Dooger2k
L2800
Dec 31, 2022
17
9
Ontario
When you turn the key, do you hear any "clicks"? My guess is the HST pedal did not return to center. Quick and easy, hold the key in the "On" position and rock the HST pedal backwards then forward and see if anything happens....
Son was blowing snow at Christmas, tried starting after no go. Glow plugs work, dash lights up but no click, no crank. Tried HST trick, nothing.
5,257
1,043
You have not done the important tests shown in my earlier post.
It is not suddenly going to fix itself.
There are more involved voltage drop tests you can be given but all require you to have a multi meter and know how to use it.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
538
510
Lake Almanor, Ca
I know this the obvious thing…but that seat has a safety switch…which on mine needs to be banged once a year or so…so that it will start.
Dooger2k
L2800
Dec 31, 2022
17
9
Ontario
Turned out to be bad PTO safety witch. Jumpered and it fired up.
Thanks everybody
8,745
10 minute job to replace switch. Dealer call it a micro switch but nothing micro about price LOL
Excellent job replacing it, and not just leaving it jumped!
Someone's life might depend on it working!
