Lift pump
brooster
B5200, BX2360, L3940, Z781i KW
May 15, 2021
68
Troy NC
Is there a way to check a lift pump to see if it’s ok? Will filling the bowl with inlet and outlet lines up work?
6,308
hmm, should be able to disconnect the outlet side, plumb into a big pop bottle, turn key to on.....
it should fill the bottle....
be SURE to secure th ebottle BEFORE turning the key on though....
11,141
Just temporarily eliminate it and see if you still have a fuel in oil issue.
This can be done on most models of tractors by just keeping the tank full, gavity will do the work.
if the tank level is lower then the injection pump inlet, then just add a low pressure, low flow, electric pump, or bottle / jug feed it from above the the injection pump, you will also need to reroute the return line if you do a jug above the pump or you'll just fill the original tank.
Also note if you leave a jug connected to the injection pump and the level of the jug drops then the injection pump is leaking.
brooster
May 15, 2021
68
Troy NC
I have the pump off the tractor because I’m getting fuel in the crankcase, I am wanting to find if the diaphragm has failed
11,141
That's an easy test. Compress the pump with a fuel feeding it and the outlet blocked.
If fuel comes out the wrong places it's bad.
3,936
2,437
Assuming, related to your other posts, you're concerned with it leaking into the crankcase; take both hoses off, plug the outlet port, blow into the inlet port (with your mouth, no more than 10 psi), there should be no flow. If you detect leakage or hear any, the diaphragm is leaking.
If the oil level is rising with the engine off, bypass the lift pump with a hose from the separator/filter straight to the injector pump. If the level still rises, the problem is the injector pump, or possibly an injector.
Are you sure this is fuel and not hydraulic oil?
brooster
May 15, 2021
68
Troy NC
So what you are telling me is that if the oil level increases over night just sitting that my injection pump is most likely the culprit for the fuel in my oil
brooster
May 15, 2021
68
Troy NC
The oil smells of diesel, where would hydraulic fluid get into the crankcase?
3,936
2,437
You probably have an engine-mounted hydraulic pump, which also has a seal. But, assuming you relieve the hydraulic pressure when you shut down and since it smells like diesel, it probably isn't hydraulic oil.
11,141
You do know that the oil will always smell like diesel, it's normal.
That's not any indication that you have fuel in the oil.
Is the oil gaining volume significantly?
brooster
May 15, 2021
68
Troy NC
In the past 2 days after approximately 20 min run time and the sit time the level has increased about 1/4”
3,936
2,437
Did you try bypassing the lift pump? It'll still start and run at low load without the lift pump if you have a fair amount of fuel in the tank.
11,141
Yes like PoTreeBoy said, you need to do it again without the lift pump in the system.
