BX 1870 dies intermittently
restopaul
new egypt, nj
My BX 1870 will sputter and die during use. Crank it for a while with throttle open and it will start, sputter, spit black smoke, and eventually run fine again. Sometimes will have this problem when starting (whether cold or got engine). I've replaced fuel filter at engine and replaced filter under the tank with a filter/water separator. Sometimes it will run for hours with no problem, today it quit four times over a couple hours. Kinda hard to troubleshoot with it being so intermittent.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
If you replace all the fuel filters (3 ?) do you use any additives in the fuel like biocide or other.. If not you may want to consider using them.
2,864
If I teed a gauge in, what sort of pressure should I get from the electric pump?
about 3 psi
but unhook the hose at the filter near the engine........ turn and hold key, should have a good solid stream.
