B21 3 point hitch, what will the E-Bay hitches fit?
Ricknsharon
Kubota B21 with BT751 backhoe
Jan 8, 2022
Charlotte, NC
Edit: here is the link to the hitch that I am referring to: https://www.ebay.com/itm/234633371656
I was able to remove the backhoe from my B21, I had a little problem moving the release lever but nothing that a little heat and WD40 didn't fix, now they move freely and plan to install a grease zerk on the pivot which should help.
I would like to install a three point hitch on tractor to use a 48" tiller but not sure if the hitches that are readily available on E-Bay will fit a B21, they say the hitches will fit the B series tractors but the B21 is a little different than the other B series. I emailed the seller and they replied that if the dimensions shown are correct it will fit. I can check the pin sizes but since I don't know what the length of the arms should be I can't be sure until I install it and see if it will work. The hitch is not returnable so I'll be stuck with it if it doesn't work out.
Also, do any of you have first-hand experience with the hitches available on E-Bay? I'm assuming they're an import but I have called all the dealers in my area and none have a used hitch available and I can't afford the high cost of a Kubota hitch.
3,636
It may help others to help YOU if you posted the link to the hitches you are asking about.
hodge
Nov 19, 2010
2,954
517
Love, VA
I don't think it's correct. The set up on the B21 is very similar to the B8200, which the ad says that the kit won't fit. Further, it says that the limit is 15 hp. You may be able to make it work, but I don't think it's a direct fit.
You could contact Weavers Compact Tractor Parts (www.compactractorparts.com), and ask. They sell complete 3 point kits, and they may know which one is a fit.
