Oil Type
avpowerstn
B7200, FORD 545A (cream puff)
Jul 15, 2012
30
Lancaster,CA
Hello
I have a 1984 B7200, I was getting ready to do an oil change.
My question is, should I use 10w-30w, or the newer 15w-40w Heavy Duty Valvoline for diesels? I believe the Valvoline 15w - 40w wasn't around in 1984. Oh yeah my outside temp's range from
9 degrees (low) - 112 degrees (high). Any help would be appreciated.
hodge
Nov 19, 2010
2,950
514
Love, VA
If it were my tractor, I'd be comfortable with either weight. Just make sure that you use a diesel-rated oil- I know you mentioned it about the Valvoline, but I'm not sure what you are refering to in the 30 weight.
I run 15w-40 Rotella in my B7100. That's all it's ever had in it.
And, welcome to OTT!
avpowerstn
Jul 15, 2012
30
Lancaster,CA
Thank you Hodge
the 30w was what the owners manual was calling for,(actually 10w-30).
I use the 15w-40 in my truck, and just wanted to make sure I could use it in my Kubota. Also, Thank You for the welcome, this site is very cool.
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
just make sure the oil has a 'cd' rating somewhere on the can.
most newer oils have a 'cdi-4' rating which is a low ash oil for newer diesel engined vehicles..
hodge
Nov 19, 2010
2,950
514
Love, VA
Thank you Hodge
Sorry if I confused you- when I refered to 30w, I was just referencing the second number- I knew that you were looking at multi-viscosity.
I belong to two other tractor forums, a dodge diesel forum, and a few others. I would proudly say that OTT is the best of the lot, which is big compliment. There are good folks on the other forums, too. But, I don't feel as close or welcome as I do here. Hopefully you will come to appreciate it as much!
