Issue loading tires
Monty72
L3901
Jul 29, 2022
Pittsburgh
I have a brand new l3901 and am attempting to load the rear tires with windshield washer fluid. I put the back on jack stands but once I let the air out they pull off the bead. Any ideas? They're r14 hybrid tires.
3,618
Yeah, sometimes. About the only thing I’ve ever gotten to work is have the air/water adapter within reach, inflate tire to max pressure, pull the valve stem, and get the air water adapter threaded on as fast as you can. Once your air/water adapter has the valve stem sealed again, you can bleed off more air as needed as you’re pumping the windshield washer fluid in but just don’t bleed the air to the point it can come off the rim. You probably know what you’re doing but in case not so much the below is a short practical on how it’s done. Yes, the background music is insufferable, but mercifully short. Don’t know why some people feel obligated to use background music on something like tractor tire ballasting videos.
Monty72
L3901
Jul 29, 2022
Pittsburgh
Thanks. As long as a have a few pounds of pressure in there they stay on. Funny because normally my problem is breaking the bead. I'll give that a try.
3,843
Your tires are too new and haven't relaxed since they were stacked after being produced. Just be glad that you didn't have to be the one to mount them on the rim. The factories have special machinery to push the outer tread to force the beads to seat on the rim.
3,843
Set the valve at 12 O'Clock, and fill to the specification on the tire. Check it periodically to make sure that it is at the proper inflation. You don't want that tire to blow off the rim due to low pressure.
William1
BX25D
Jul 28, 2015
1,085
269
Richmond, Virginia
Put a stout ratchet strap around the tire in the center. Make it as tight as you can. That will squeeze the tire and force the beads outward
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,392
2,306
^^^yessir! Just know it has to be a heavy duty one. Like one that tractor trailers use to secure a load. The Harry Homeowner type might work if you use a few of them.
Crash277
BX23S
Jan 17, 2021
846
622
this!! done this on a bunch of different rims. a nice 3" wide strap works great
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
134
141
Demotte, IN
You could try wrapping a chain or rope around the tire and tightening it to keep the tire on the bead. I have done this on smaller tires.
4,063
they sell 'bead sealer' stuff....helps 'bond' the rubber to the rim. I've used 'fan belt dressing' for decades on little riders....
also used the rope and pipe trick, turn the pipe..tightens the rope....tire gets smaller (like a tourneqet (sp)).
