I have a 2007 Kubota 6040 that I purchased new.  I keep it at the farm which is four hours from where I live.  At times it goes three or four months between start ups.  Yet, 1/2 second of starter engagement usually starts it running smoothly.  It has less than 250 hours on it and new hydraulic filters, oil, engine filters and oil....etc.  It is well maintained.  About a year ago it wouldn't start properly.  By filling the screw on filter, filling the water separator, priming the plunger, etc. I could get it to start but it wouldn't run long.....20 to 30 seconds then quit like it didn't have enough fuel although the water separator still indicated the proper amt of fuel. Sometimes the screw on filter was low on fuel, sometimes not.
I took everything apart and cleaned it...separator, inlet, valve, outlet, new fuel filter, new lines, new fuel pump and a new cap for the screw on fuel filter. My Kubota dealer is 45 min away and closed today. After all of that I eventually got it running properly.....probably 12-15 hours worth of discing and bush hogging. This trip after sitting for three or four months....same problems. The tank has plenty of fuel, the separator is clean, the valve is on, the screw on filter is full. The fuel pump seems to create adequate suction but pulling the outlet hose doesn't show a lot of fuel pumping....some fuel mixed with bubbles of air. The inlet side of the fuel pump seems to have adequate suction. Suction pulls fuel through the fuel line from the tank which is 3/4 full. If I fool around with it...fill filter....it will start but not easily.....30 seconds worth of cranking. Then it will sometimes run smoothly, Rev it up and the fuel level will move up and down in the separator. Then it seems to run out of fuel. Quickly pulling a line doesn't show any built up suction like something is stopped up.
I can fill the screw on filter...necessary???? pull the inlet hose to the fuel pump, stick the end in a can of fuel and then start the engine after another 30 second effort. Apparently excess fuel is fed back to the tank because the container fuel is sucked down pretty fast. I pulled a small, 1/8" line off the rear of the injector block and fuel does spurt out when turning the engine over.
Why putting new parts on it a year ago got it running I don't know. Even then I initially had problems starting the engine....then one time it ran fine for days and hours.
Now it is back to the same issue. Removing the tank fuel cap does not help. Fuel is fresh. I've taken an air hose, stuck it in the tank filler hole with a rag around it. Pressurised the tank a bit and fuel flows out of the fuel line at the separator.
If there is a problem in the high pressure pump I don't know how to assess that....but it seems if there is a problem there it would be continuous. I've had the engine running for five minutes this morning....nothing leaking, fuel level moving up and down in the separator bowl as I raise or lower rpm. Then it is running along fine until it decides to quit. Something is off because this engine normally starts with a very minimum effort.
Ideas? I'm out of them. Thanks much. 1917
