Just bought a L185DT, 1977 - 1982
JayJay
L185DT
May 17, 2022
Acton Ca
Just bought this tractor L185DT. Runs good but it is stuck in gear. I am able to drive forward even though the shift lever is in neutral. When you push in the clutch and select a gear ( forward or reverse ) the tractor will not go forward. The tractor acts as if the breakers are locked and motor will stall if you let the clutch all the way out.
It had the top of the trans open when I bought it. Reassembled the shift forks etc. and everything looked okay,
Could it be something to do with the high low gear selector ? Why would there be a neutral on the high lower gear selector ? Thanks for any thoughts or ideas !
1,004
I recall posts of similar problems that mentioned the shifter forks not working properly due to wear or bad assembly.
Search shifter forks for a few things to try
This thread sounds like what you may be experiencing.
5,128
933
There is a neutral between the Hi and Low range selector positions.
You are definitely in two gears at the same time hence the locked trans mission.
Open the top again and study it carefully.
Don't put the cover back on until you can let the clutch out without stalling the engine.
Have engine at low rev's and expect some oil to the thrown out.
If you want the operators manual, use the envelope symbol located in the top right corner of the form page to send me your email.
Do not post your email where everyone can see it
JayJay
L185DT
May 17, 2022
Acton Ca
Thank you! I appreciate your help.
2,424
1,243
The reason there's a neutral between H and L is the sliding gear has to disengage from one gear before it can engage the other. Otherwise, it would not be able to 'find' the other or, if it did, the gears would bind due to being in two gears simultaneously. Similar to the problem you're having in your transmission.
