Hello,
New Kubota owner and group member here.
I just got my B7100 put back together after taking the manual transmission in to the local Kubota dealer for repair.
The splines to the front drive on the front of the transmission were broke off, the connecting u-joint missing, the input seal and support housing damaged presumably when the front drive splines broke and it leaked a lot of oil from the seal. That was all fixed at the dealer.
I got the repaired transmission installed and the tractor back together and topped up with oil. I then put the front and rear wheels up on jack stands and ran the tractor in 1st and reverse gear with the 4WD engaged to confirm there were no issues with the front diff that may have caused the drive splines to break. The front and rear wheels turned with no abnormal noise or issues. I put it back on the ground backed it out of my garage and took it for a test drive down in my field trail.
it went down the trail a good ways with no issues. I dropped the FEL and pushed some dirt to even up the trail in a spot, still no issues. I did the same in another spot and then went to put the tractor in reverse and when I released the clutch the engine stalled. I restarted the tractor and tried this time to put it in 1st gear. It stalled again when I released the clutch. I put it in neutral and tried to get it to roll and it acted as if the brake were set or the driveline was bound up. It wouldn’t budge.
I should also mention that I had the rear R4 tires foam filled when I had the transmission off for repair to add some weight for traction and make it harder to roll over since I have some steep grades on my property.
Any ideas what I might check or where to start? Major work on it is going to be a challenge since it’s basically stuck in the field as-is.
Thanks in advance!
Thanks in advance!
