Which engine oil for BX2380?
RalphVa
738
321
Charlottesville
I wonder about the huge amount of capacity that exists for refining dino oils. I worked for 31 years for the largest of them, which is even larger now with the merger. Now, the Singapore combined lube oil plant is their largest. Only a small amount is engine oil though.
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
201
80
Thanks for all the replies! You're helping me to learn quite a bit. I'm new at using diesels.
davep
LX2610SU, RCR1860, BB1260, QH10, CID HBHS, CID CTFF, WR Long RBG2
Jul 20, 2021
51
17
Kubota, Shell, Mobil, Shell Rotella
15W-40
API: CH-4, CI-4, CJ-4 (Edit: page 73 or the Operator's Manual says this cannot be used on this tractor), or CK-4
As for the filter, on my cars I've ALWAYS changed the filter when I've changed the engine oil otherwise the new, clean oil I pour in is dirty oil after the car is started.
Any comments/advice will be appreciated.
Yes. 15W-40 is what the dealer told me as well (in Virginia). He said not to use the 5w unless you were further up north and operated in the winter.
pgmrdan
Aug 16, 2017
201
80
Thanks!
10w-30 would cover the winter temperature range here too but the service manager at the dealership told me to use 15w-40 so that's what I'll use.
