PTO in Neutral?
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
I have a B2650hsdc that I recently started using the rear PTO on a wood chipper. My question is, is there a way to put the PTO into a neutral position, so that when I’m trying to connect the PTO shaft to the chipper it can be rotated to align the splined shaft? It is a real pain to rotate the 200 pound flywheel on the chipper to get the splines lined up. I’ve tried several combinations on the PTO levers and don’t seem to be able to get a neutral position.
5,815
I just looked at the dwgs online and it looks like the 'PTO shifter' should mechanically disengage the PTO shaft from the PTO clutch.
I agree though you should be able to freely spin the PTO shaft ,every tractor I've ever had, you could.
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
322
311
catlettsburg, ky
Put your pto selector in the mid pto only slot. The farthest to the front slot.
If that doesn’t rotate, slide the selector between the front selector slots and try to rotate the pto shaft.
WITH THE ENGINE OFF!!
Elliott in GA
Mar 10, 2021
820
830
North Georgia
I believe you should select the Mid-PTO (only) and Neutral transmission to free the rear PTO. I have an SU (no Mid-PTO) so my PTO shaft is never free.
I rotate the attachment's PTO shaft to mate with the Tractor PTO - easy to do on rotary cutter and spreader. However, the finish mower is another story; there I use a PTO wrench ($20). I mount the PTO shaft to the tractor, and then I connect to the finish mower using the PTO wrench. It only adds about 1 minute to hook up time.
3,264
Different tractor, but with my BX2200 I had a similar issue when putting my MMM back on after spring maintenance.
I did find a position of the selector lever, somewhere between one of the three choices...not sure which it was...I have front-mid-both sections...and the PTO shaft then moved freely.
Maybe the solution is just trying different selector lever positions...worked for me.
DeepWoods
Apr 10, 2019
342
282
Bigfork Minnesota
After playing with it after my OP, I found that moving the PTO selector to the mid PTO only position I can rotate the rear PTO shaft about a quarter revolution. All other levers have no affect on rotation, reguardless of position. The quarter revolution is enough for me to get the PTO shaft of the chipper aligned. Problem Solved, thanks for all the replies😉
DeepWoods
Apr 10, 2019
342
282
Bigfork Minnesota
This looks like it would have solved my problem if I hadnt found the correct lever positions. Something to keep in mind though as it might be an easy solution as well
DeepWoods
Apr 10, 2019
342
282
Bigfork Minnesota
Not sure how I got to this posting that was from last summer, but it is discussed again in detail as to the same problem. Thought linking them together might help with others that have this problem.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,035
1,439
Pittsburgh
From the BX23S manual:
On the BX series, and perhaps others with hydraulic clutch PTOs, there is a spring powered brake to arrest drift of the PTO.
xrocketengineer
Nov 14, 2020
835
784
Merritt Island, Florida
I could not figure out from the WSM transmission disassembly, how the PTO's are selected. But it appears to me that since the brake engages the selected PTO to stop it as the clutch disengages, then the "unselected" PTO is not engaged to the clutch nor the brake and therefore should be free to be spun by hand. Does that make sense to you guys?
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,035
1,439
Pittsburgh
I see it.
See how the rear most gear is in dashed lines? That is actually the alternate position of the "middle" gear. It slides between three positions: forward, rearward, and middle. The middle position bridges the two intermediate shafts which would be both PTOs powered simultaneously. They should be free when the other is selected.
xrocketengineer
Nov 14, 2020
835
784
I see it.
I see the slider gear now and the groove for the fork. Thanks!
Vigo
B6100, B8200
Jan 9, 2022
595
341
San Antonio Texas
I had read somewhere that the BX had a 'pto brake' but it never occurred to me to wonder if it would make the pto shaft harder to line up. Sounds like a workaround has been discovered, though.
Makes me wonder.. would an overrunning clutch attachment for the pto shaft be easily enough turned by hand to bypass this issue? Probably not a valid reason to buy one, but it begs the thought and i've never seen or touched one personally.
EDIT: Whoops, looks like that question is answered explicitly (yes, it works) in post #5 of the thread linked above. Well, now i know..
JOLJ
L4701 Tractor with LA765 loader & BH92 Ba, RTR1274 tiller, RCR172 Rotary cutter,
Jul 3, 2023
South Carolina
I have a small L4701 Kubota, bought in 2020.
I have a twist button, no mid range PTO CONTROLS.
So how do I get the 6 spline shaft to rotate by hand?
3,932
2,582
FYI My tractor only give you about a quarter turn each way on the PTO. They don't all spin freely in neutral.
3,478
2,052
You probably can't. Like many tractors with hydraulic PTO clutches, there's a spring activated brake that engages when the clutch disengages.
