B50 series w/ROPS owners, watch out for this...
nbryan
Jan 3, 2019
1,302
825
Hadashville, Manitoba, Canada
I operated my box blade with the ROPS folded fully down for the first time this spring.
Then I was wondering what the f*** bent my top link, and also the inner bar of the adjustable right side anti-sway linkage, when I went to change the 3-point over from the BB to the trailer hitch receiver.
Here's the answer:
I could bend the sway locking-bar straight. The top link is pretty much toast. $100+ for an aftermarket replacement. $250 for the oem link ffs.
I scoured my operator's manual for the warning that should be there and I obviously ignored, and sure enough, p. 27, in part -
"Before proceeding to fold ROPS, check for any
possible interference with installed
implements and attachments."
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
Dooh, I hate that for you. Luckily I have no need to fold down the rops, and I'm way too lazy to do it for no reason, so I haven't run into that problem. Thanks for posting, may help someone else down the road, good karma.
8,713
May we all learn from the misfortune of others, others being you in this case!
3,202
AND...if this is the worst misfortune you experience when using the tractor with the ROPS down, even better.
The ROPS and seat belt are there for a reason. Hope you use them when you really need to.
radas
Mar 21, 2022
719
834
Here's the answer:
Now's a good time to upgrade to a hydraulic top link if you get the chance. @Daferris Holland top link recommendation for the B2650/LX2610 was around $259 IIRC. I saw this on a YouTube video a while ago, sorry to see it happen to you, but thank you for the reminder!
RalphVa
738
321
Charlottesville
Same is true for the B01s. I put my RB on it and fortunately had the top link all the way in. The QH was bumping the folded down ROPS. If the top link had not be in all the way, I would have bent it.
5,261
I warned someone of this happening not long ago. Hope it wasn't you nbran.
