Three point hitch won’t go down
Gnilde
Ocean View NJ
I had a friend install a three spool rear remote To operate a top link and side link. The rear remote works but when they used the existing lever to raise the three point hitch it wouldn’t go back down. Anyone know what is wrong?
Thanks
Claude
3,160
1,770
Thanks
Claude
Assuming we're talking Kubota, somewhere between your legs there's a knob that controls the lowering speed. If it's turned all the way off, your 3PH won't lower at all.
Welcome aboard. If you add your location and equipment to your profile, folks can help you better.
Edit: I see your location.
8,515
If it's not the drop speed adjustment causing the issue, then it sounds like he may have tapped into the wrong connections to add the remote valve.
Will need pictures of what he did.
