B2601 Hydraulic oil check
milanmark
B2601, Bucket, Grapple, Brush hog, stump bucket is ordered!
Jul 7, 2021
78
38
Milan, MI
Read a lot of times that the hydraulic oil needs to be checked frequently... So where is the dipstick? I know where the engine oil dipstick is... and the trans dipstick back by the 3 point hitch... even my manual doesn't show a hydraulic oil dipstick! Is the trans and hyd the same one?
Tractor is only 6 months old so still learning it!
Thanks
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
101
55
Traverse City, Michigan
The transmission and hydraulic system use the same resivor and use the same dipstick by the 3 point. Also don't forget to check your front axle fluid if its 4wd.
milanmark
Jul 7, 2021
78
38
Milan, MI
Thanks for the quick reply!
I do have 4WD, how do you check the front axle?
Gene Blister
2019 Kubota B2601, FAL LA435, Snow Blower BX2822A, Land Pride rear blade RB1572
Aug 4, 2019
81
20
Cocolalla, Idaho
The front axle inboard of the right front wheel. It’s a black rubber cap with the fill levels on a tiny dip stick. You gotta kinda twist, squeeze and pull to work it out.
Youre going to love that stump bucket, good for so much. I make electric and water line trenches with mine. Remember your 2601 is a smaller tractor, and you use the stump bucket to excavate far around stumps and boulders and sneak up on depth slowly. You can’t just push the nose under the target and lift.
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
397
289
right coast
Make sure you get that front axle cap back on properly. As stated above it is a little difficult to remove, also somewhat difficult to properly re-install.
