Which oil for Kubota B1402?
Rosohatica
Kubota L3200, Tehnos MULS 130 flail mower, Fužinar 14” plow, Landforce 5′ tiller
Feb 23, 2022
168
39
Zagreb, Croatia
Hello and thanks in advance,
I own a Kubota B1402 from 1986. , and I want to change the hydraulic oil.
According to the label inside the unit the oil is M80B, the same used in front axle and transmission.
I can`t find such oil on the market here (Croatia, Europe) Can someone please suggest what would be good replacement modern age oil?
Best wishes
9,110
Since your in Croatia, and not the USA, You probably won't be able to get UDT or SUDT2.
Look at the labels for fluids compatible to Kubota UDT.
Don't go with the cheapest and you should be fine.
3,630
Mobilfluid 424 is a European equivalent to Kubota UDT. (according to ExxonMobil Belgium)
Mark_BX25D
Bx25D
Jul 19, 2020
1,843
1,336
Well, that can't be right! I don't care if Kubota published that! There are too many experts on here who will solemnly affirm that the composition of Kubota UDT is a deep, dark, sacred secret, far superior to any other fluid, and cannot be duplicated by other companies!
If you try to use other fluids, you will void your warranty, blow up your tractor, and likely cause the mass extinction of all the blue pikklepoppers in Lower Slobovia!
9,110
Sorry that deep dark secret would be SUDT2!
landbastler
Germany
Hello Rosohatica,
you write that you have a Kubota B1402 from 1986. We also have a tractor like this here that is probably from this year. Can you write your tractor's serial number here so we can compare it with our serial number?
There is no year of manufacture marked on our tractor. Only the production date of the rims refers to the year 1986.
Best regards from Germany
landbastler
