Loader Alignment??
J-Cub22
L4060, JD 5425, NH 5030, Polaris Ranger 1000.
May 24, 2021
29
27
Tennessee
Wasn’t sure what to title the thread, but the pics below explain what I’m talking about. I’ve not abused, banged or done much with the loader other than handle rolls of hay. Any ideas what may be causing this and is it a potential long term issue? The other side is not wearing like this at all. Thanks
5,765
Without seeing a parts diagram, I'd think someone didn't install a shim between the upper front pivot ?
hmm, maybe measure the gap at several places, on both sides, to see what is 'different' ?
J-Cub22
May 24, 2021
29
27
Tennessee
Hadn’t thought of that, I’ll do that. Thanks
rbargeron
Jul 6, 2015
1,182
259
western ma
There have been several pictures of recent loaders where the edges of loader arms are rubbing - likely just slight inaccuracy of weldments in manufacture. Probably won't cause future problems - it may just "wear in", with the rubbing force getting less with age and use.
To put your mind at ease watch it move with and without a load. Having a helper operate the lever, you'll see if what's contacting what and when. Of course if there's a lot of unexpected motion there may be a broken weld somewhere that should be properly repaired. Dick B
5,178
Agreed!
Most likely a shim washer is missing
kubotafreak
Sep 20, 2018
1,049
397
Arkansas, US
Dealer should be able to get you new front quick attach plate, and links. There was a weldment issue on la805.
J-Cub22
May 24, 2021
29
27
Tennessee
Thanks all! I did look today and there is a difference from side to side in the gap, or shim space, on the loader joints if you will. I’m going to call my dealer tomorrow and see what they say. I’d honestly like these pieces/parts replaced but I’ll see what they say and update. Thanks again!
Servmgr64
Kubota Grand L3010HST, BX2350 various implements
Jan 6, 2016
11
Poweshiek county Ia
I am having the same issue on my L3560 with LA805 loader. Is there a recall or special policy that covers this? Is Kubota stepping up for the repair?
Thanks
Scott
kubotafreak
Sep 20, 2018
1,049
397
Arkansas, US
Cant speak for your dealer, but it has been a known issue. But, consider right now people are waiting 7months plus for a new la805. So who knows how willing they will be to help. I believe it is in the skid plate. The link is casualty to its missalignment. I suggest if you get new parts shim appropriately with arbor shims. Tractor supply has a arbor shim pack that would be your cheapest alternative.
J-Cub22
May 24, 2021
29
27
Tennessee
Dealer said they’ve seen a few like this in the last year or so. They told me to bring it in and they’d replace the parts under warranty. They weren’t specific as to what part/parts they’ll replace, but that they’ll fix the issue. My local dealer is great and thankfully I haven’t had to use them much!
5,765
nice to hear you're being taken care of properly !!!
be nice if they can order the parts THEN schedule to come in to do it ,so you're not withou it for long.
