my tractor cant keep coolant...
OlFerguson
4440, 1120D
Jun 1, 2017
198
12
My m100x is leaking coolant pretty good and hard to detect the source of leak....Ive changed the top hose, thermostat and gasket and its still leaking like a civ. Im wondering now if its the water pump. Any tips on how to nip the leak point. I start the tractor and seconds it starts leaking. Hard to tell with the fan blowing it everywhere. Thxx
Daferris
LX2610
Nov 23, 2021
496
423
Mid-Michigan
It is very possible the seal for the shaft that drives the impeller is leaking. Should be easy enough to pull off the fan and pulley to see if the inside of the pulley is wet
OlFerguson
4440, 1120D
Jun 1, 2017
198
12
i have a pit to pressurize the system but its more for cars. Be nice if it worked on my equipment. Ill have more a look in daylight in the shop
JimmyJazz
1,273
805
Pittsburgh, Pa
Flour or talcum powder applied if possible in the vicinity of the leak will help detect the source of your leak. Good luck.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Pressure testing it is the first thing that comes to my mind. Pulling the fan belt is also a great suggestion
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
I also suspect the water-pump seal. You can temporarrly remove the belt and run engine for a minute or so to help isolate the leak.
3,115
Add dye to radiator and use special glasses and light to locate the leakage source.
Kit available at auto parts store
OlFerguson
4440, 1120D
Jun 1, 2017
198
12
having a hard time finding the specs for the rad cap so i can find a tester cap for it. Will let you know when i find the leak.
5,255
1,058
You can pressurize through points other than a rad cap.
I have remove the bypass hose and plugged on side and put a schraeder valve on the other side.
Just do not get carried away using compressed air. Better to use a big bicycle pump so the air is added gradually.
OlFerguson
4440, 1120D
Jun 1, 2017
198
12
after realing my thermostat unit and pressure testing my cooling system im back in service, well for most of today now i have another issue lol.
