Snowblower gearbox oil replacement
DS_LX2610
KB2510 with loader, bucket, fork lift, and residential snow blower
Nov 9, 2021
9
Big Fork, MN 56628
I need oil in my snowblower gear box and cannot make it to a Kubota dealer. I have an L&M Supply near me that has the 80W90 oil that the Kubota manual calls for, but the manual also mentions AGMA SEP which is extreme pressure oil. When I check the L&M site it only says that the oil is 80W90. Is it OK to use that oil as a replacement for the Kubota version or does this extreme pressure require that I only use the Kubota oil?
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
There are other brands which offer extreme pressure gear oil - kubota is not the only vendor. Read the specifications for the various oils L & M offers.
Roadrunner17
21
Apparently all of the 80w90 gear lube is so called extreme pressure it goes in a gear box I put napa premium in mine and no problem
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
394
56
Wa
I did a quick search and, as stated, it does seem all are formulated for this use.
Valvoline, Mobil1, Amazon brand, Master Pro to name a few.
3,944
You need a GL4 gear oil since the GL5 gear oil is known to attack the yellow metals, more commonly known as brass. GL4 is safe for brass. If you have an older car with a brass synchronizer you would be aware of this.
DS_LX2610
Nov 9, 2021
9
Big Fork, MN 56628
Thank you and all others for your prompt reply. I called my local Napa dealer and they do have extreme pressure 80w90 gear oil so I am going with that.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
327
252
Bigfork Minnesota
I used the Amzoil extreme duty 80-90w that L&M has in stock. Not cheap, $20.00 for the bottle. Drained the OEM after the first year and put this in. No problems yet. I see you are from around Bigfork, which way. I’m about 20 miles east, on Napoleon Lake.
nbryan
Jan 3, 2019
1,169
711
Hadashville, Manitoba, Canada
I'm about 150 miles northwest of you in SE Manitoba, and we have very similar equipment!
3,944
I see that many of you are disregarding the fact that the gearboxes of snowblowers use brass gears, and GL 5 isn't good for the brass. Don't want to believe me, then read this and then decide for yourself if you want to risk damaging your gearbox. If you don't want to read the whole page, then just skip down to "Which one is better".
JWool
B2650HSDC FEL & Front Snow Blower, ZT-Z421, GL11000 Generator
Dec 29, 2013
97
17
Northern MI
I used Amsoil Marine gear lube 75W90 because thats what I had, also thought it might be good if any moisture gets by a seal.
Donystoy
Dec 10, 2013
504
165
Binbrook, Ontario
I see that many of you are disregarding the fact that the gearboxes of snowblowers use brass gears, and GL 5 isn't good for the brass. Don't want to believe me, then read this and then decide for yourself if you want to risk damaging your gearbox. If you don't want to read the whole page, then just skip down to "Which one is better". (quote)
My research tells me that this is only a concern at higher than 150 deg f where some of the EP additives might react with soft metals such as brass. The gear box on my blower stays cool after clearing my 4000 ft. driveway. This is certainly something to be aware of with gear drives though.
