New here 3 pt hitch for G1900
Skipper
14
Maine
Hello, I just purchased a 2000 G1900 that came with a new 3 pt hitch. Is there any diagrams on this website or others that show the set-up. My son seems to think the 3 pt hitch doesn't even go with my new G1900. Thanks!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Any chance you can post some pictures of what you have, tractor and hitch and lets see if we can getchya figured out and squared away. The G series is a garden tractor which has a Cat 0 three point hitch, which is rather small. So the parts you have wont be very big.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Yeah those are the wrong ones. Those are Catagory 1 hitch parts which is a pretty common hitch but way to big for the G series mower. Catagory 0 is better suited to the G series mowers.
Skipper
14
Maine
Thanks Eric, my son thought so too. Searching on the internet, I found the 3 pt hitch for the G1900 is part number G2590. Do you know if you can still order these from Kubota or will I have to search Craigs list? Thanks!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
You'd have to check with Vic on that one, he's the only person I can think to ask.
Service Dept Vic
Skipper
14
Maine
Well, it sure appears the hydraulic 3 pt hitch for the G series is a rare if not non-existent item, does anyone have any ideas on how I could fabricate a hitch to raise and lower a scraper / plow on the rear.
Freakingstang
NE Ohio
I've been looking for a year.... I did find a diagram of the optional kit.. One dealer I spoke with remembered installing one way back in the early/mid 90's. There was a diverted valve that switched between the rear "3pt" and the mid lift cylinder. It had no down pressure... It was also a 900 dollar option....
I have fabbed up a rear Reese style hitch and have all the parts for my own design cat 0 three point. I have aquired many different hitch setups from old brinly sleeve hitches and craftsman. I haven't had the time to finish it. I had a thread in the fabrication area where I built a front snow blade from a 5100. I tapped into the hydraulics and left myself an extra port on a manual three way valve I bought. You are probably going to be better off to either find or make a front blade. It will be easier and work better as long as you can get enough weight on the ass end. I filled my tires and made a 150lb weight plate that slides into the rear hitch I made. The original g series snow blades are very cheaply built. They are all bolted together with very thin steel. I looked for about a year, ended up finding that Hyd front blade and made it work. Then after all the work I found a front snow blade for the g series (g2001 iirc) and was very disappointed in how weak and cheaply built it was.
Steve
Skipper
14
Maine
Steve, it seems that from what I've read this hydraulic 3 pt hitch is very hard to find. Luckly, my son and a close friend are pretty good welders/ fabricators so I will probably have to make something close to the real thing. Nice job on the plow!
leveraddict
Apr 1, 2019
905
590
NEPA
Do you still have g 1900 I have a question about it thank you
Start a new thread and ask away! The OP your asking the question hasnt been on here since 2013!
