Hi all-
B2601 approx 500 hours; zero issues until Sunday morning. Tried starting and nothing even after a jump attempt. Here are the symptoms:
-no “clicking” from starter
-ignition powers all circuits (accessories, glow, and starter)
-wire from the ignition switch to relay module is working, however the black/white wire to solenoid does not power when ignition turned to start.
-battery is fine
-motor is not seized
-starter and solenoid move freely with no historical issues
-unit is in neutral and PTO off position
-unit was outside that night so I did check for critters or other sabotage- none to report
-basically have stripped the unit down searching for the issue
-plenty of clean fuel
-this all happened after fall cleanup and running the unit for approx 3-4 hours
So I am thing safety switch from PTO or treadle pedal. Does anyone have experience with issues of this sort?
is there a way to trick the safety switches to further analyze if the relay board is the issue?
Thanks
-battery is fine
Thanks
