BX2380 hydraulic leak onto mower
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
Howdy. My quick disconnect has a leak on the last port closest to the seat. It has dripped down onto my mower deck into the spindle area for the drive belt. I will get to it today and fix the leak, but will I need to replace the mower belt? Or will it dry out after a few thousand spins?
2,913
I would remove the belt and "clean" it the best you can and replace it back on the spindles after the leak is fixed.
I would be worried it may want to slip and cause a heat build up and then harming the belt more.
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
Thanks I got the leak fixed. I cleaned the belt with soap and water and it is drying now. I will reinstall it tomorrow.
leveraddict
Apr 1, 2019
905
593
NEPA
Make sure your not too far away when engaging the quick connect. I had the same problem you did but just once. Once the o ring inside is damaged it will always leak. Many owners have had nothing but problems with these but mine is still working fine since 2017!
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
I think that is what happened, the last time I put it on I was in a hurry. Funny thing is it didn't leak until a few weeks later when it got colder. I will watch it to see if it leaks again.
Thanks
xrocketengineer
Nov 14, 2020
871
834
Merritt Island, Florida
I had mine leak so badly that the dealer replaced under warranty both sides of the quick connect.
