Advice on bad piston rings
Fishfarmer
Kubota tractor M4500DT Kubota excavator KX161-3
Aug 8, 2021
114
Okay guys, Sorry for the long thread but I am trying to be thorough.
Here are my engine (S2600-A) tests done. Re: previous thread, post injector ignition knock on M4500DT. Engine starts easy doesn’t run rough, has blow-by, if I remove dipstick some bubbling of oil. Only blows a bit of smoke with high revs.
Cracked each injector: engine falters, would indicate injectors not blocked but maybe still post ignition. Removed injectors tested them and each spray fairly well and pop at 1900-2100 psi.
I compression tested a number of times with excellent battery.
Cylinders 1,2, 3 and 5, 380-400psi. Cylinders 4 and 6 at 350psi and 300psi respectively. Oil squirt in #4 pressure goes to 400psi and 6 goes to 350psi. I would think, going by opinions and the manual for over 10% difference in the cylinders, that one or both of these have either very worn or cracked rings. I can’t find what positive test I can do for cracked ring vs worn rings?
I decided to compare oil squirt in good cylinder, goes from 400 to 450psi. This is higher than what a new engine states in the manual, this engine is so old it’s impossible to be so high. I think my compression tester must be reading higher than it should which shouldn’t matter, consistency between cylinders I am told is the key. It obviously doesn’t say to do oil squirt in a good cylinder in the manual. I can see oil test compression wouldn’t increase on a leaking valve because there would be no increase in pressure when the oil is added, however if assuming my 400psi cylinder and piston is pretty good and it raises another 50psi with addition of oil squirt, doesn’t that give out a false positive for the worn/broken compression ring test? To rephrase would a broken ring give out a very low compression reading on one cylinder, more than the difference I see in #4 and 6? My compression tester is reasonable (not a cheapo and does have Schrader valve). The manual says to crank for 5-10 seconds, but the gauge is only getting to 200psi after this time then starts climbing to 400psi after 20 seconds (the maximum pressure reached). I figure that the small 5mm x 10mm port from cylinder in to the firing chamber is not letting enough volume through to reach maximum pressure in this 5-10 second time? Maybe a new engine produces more volume and pressure than a tired one. With some experience testing cars which have an open head directly in to the cylinder, I have found the needle jumps quickly and only needs a few cranks to reach pressure. Not so I have found with the tractor, but I am no mechanic. Further the cylinders 1,2,3 have a clean look with light carbon deposit, but 4,5 have a bit more carbon and 6 has a heavier build up. #6 renowned for being the problem on straight 6 engines (at least with cars it is).
Leak down test using compressor on TDC I can hear air passing in to the sump very slowly on most cylinders. It sounds like a touch more air on #4, and # 6 is noticeably more than the others. Other cylinders seem to release the pressure more slowly, this test done without tappet cover on.
I made a home-made leak down tester, my air compressor goes to about 80-90 psi and most cylinders only drop to 70psi so have 15-20% leak age but to my horror #6 is dropping from 80-90psi down to around 20 psi. 75% leakage which is a huge amount of leakage and no doubt causing what blow-by I have.
I could use a decarbonizing product but if it is broken rings it won’t do any good. I have also read heavy detergents can damage crankshaft bearings as the gunk is pumped through after the detergent does its job, but if this cylinder is leaking down by this amount would it make any difference anyway. My question is can just worn/carbonised rings and bore glazing cause this much leakage? Is there still some life left in the engine or is it ready to go?
I looked at each cylinder with a borescope, there does appear to be light scouring in some cylinders
which I think is from piston skirt scuffing. The borescope only focuses to a minimum of 2 inches so it is hard to see if scuffing/scouring is deep. #6 doesn’t have a hole in the piston or damaged edge on the crown but a bit more scuffing or scouring on cylinder wall than the other cylinders.
I could take the head off and look which would only cost $200 but its unlikely to tell me more, a complete strip down is costly and I don’t think the tractor is worth it. I only do slashing for a half day 3 times a year so I was going to keep it running, listen for any changes and do a compression test and check if the bad cylinder gets any worse over time. With the info given is that ill-advised? If I continue to use it will I blow the piston or would I notice it get worse before that happens?
5,504
2,211
dumping oil into the cylinder didn't do it any good.
if you don't feel like it's worth it to repair, don't worry about just keep running it until it quits running, then dump it for what you can get out of it.
Fishfarmer
Aug 8, 2021
114
Thanks Lugbolt I might just do that. Why would you say oil into the cylinder didnt do it any good? Even the manual tells you to do a squirt of oil on a compression test. Not a running test, just a battery crank test.
5,702
Dont get too hasty impugning the gauge. Compression specification for a new engine is for dry rings. When you do a wet test they seal better and you get a higher number even on a new engine.
Fishfarmer
Aug 8, 2021
114
Thanks Dan I will note that. Its just a bit strange that my compression is 400 psi on one cylinder and the tractor is so old (40 yrs) that i figured it couldnt still have that high a compression. This tractor has never been looked after going by the condition of everything else, I doubt if the last owner ever changed the oil
5,702
Just my initial reaction to the cant be higher than factory comment. A retest with a second gauge certainly won't hurt.
Just FYI I have an old B series with significant blowby and a small loss in power that has been running that way for better part of 10 years. It just keeps on working.
Fishfarmer
Aug 8, 2021
114
A lot of tractor owners have said this, perhaps I am too pessimistic, you read forum reviews and mechanic websites that give out the worst prognosis and instill fears in people including myself. They are based on the perfect engine. I just didn't want to put the rod through the block. I imagine if I do the light work it might keep going for some more years like yours. Light work wont help with more bore glazing but hey it could be better than working that piston hard! Thanks for the encouraging FYI
5,702
I think a more likely "catastrophe" is scored cylinder(s). I am not a big fan of in-frame overhauls and I don't know the layout of that engine but new pistons and rings is not usually a terrible job and might help you sleep better. Probably more time than money. In my case money is easy but time is in short supply. Plus my tractor is disposable at this point.
Good luck whichever way you go,
5,504
2,211
I really wasn't speaking or the gauge
i posted on this a while back, but adding oil to a diesel engine while doing a compression test produces results that are often WAY off of spec. There are several reasons.
Reason #1 (and the most common) too much oil is added, and a bent rod results, and then your compression reading is low. How much is too much? Depends on the engine.
#2, the oil ignites and the engine either tries to start, or your gauge reading is way high, like buried needle on 1000 psi gauge. Maybe extreme example but you get the idea. Yes a diesel engine can generate enough cylinder compression pressure to actually ignite oil. I've done it. And I've seen it (rolled over tractor will run away). You won't forget it when this happens!!!
#3, oil seals it all up and you get high readings--which aren't always what the engine will see during normal operation. So adding oil screws up the readings in all 3 cases.
if it's low on a dry test, it's low and you can do a valve clearance check...if that's ok, you gotta pull the head anyway to inspect. The thought here is to dump a little oil in it, which tells you if it's cylinder related or valve related, if the pressure comes way up, it's cylinder related. The head needs to come off. If not, the just the valve cover (first) and if nothing under the valve over, pull the head anyway. So no matter what, if it's low, it's low, find out why and fix it or just keep running it until it's dead and then deal with it then, if it has any value at that point maybe sell it for parts or whatever (obviously it's worth a lot more running than dead).
I know some of yall do things differently than I, and I respect that--just be careful--and smart--when doing it.
3,664
lugbolt says it and I’ve always been told …. It’s not appropriate and it’s a BAD idea to add oil to check compression on a diese…..because the oil can ignite prematurely and detonate before reaching TDC and bend a rod or worse… and because some diesels have so little clearance at TDC the oil can act as a hydraulic-lock and bend a rod or worse…
It’s best to compression-check a warm/hot engine immediately after shutdown because the rings are in-position and clearances are most-nearly as they are during actual operations and the rings are already lubricated.
Oil is “bubbling”..?? Can you elaborate on that? How do you mean and how did you perform that test?
Fishfarmer
Aug 8, 2021
114
Thanks Lugbolt and Geohorn, I had not realized that a squirt of oil could cause ignition and damage the gauge ( especially the manual tells you to do this ). Hopefully I have not bent a rod from hydraulic force. I wouldn't think it could cause a runaway engine, unless one out of 6 cylinders can runaway (all injectors removed). Compression tests are finished now and I will take advice never do an oil squirt. Lugbolt is correct, if compression is low oil squirt is not going to do anything. The leak-down test is a much better idea for diagnosing whether its valve or ring related IMHO. Since my post I have done more static cold leak testing on the bad cylinder. Result, mostly leaking past the rings, I can hear it at the lower filler tube, some leak at the valves, possibility carbon. I removed the push-rod rockers on these and pressed the valves up and down until I could hear them seal, rather couldn't hear any airflow from inlet or exhaust. I don't know how strong the valve springs should be to be able to do this, but I could press them by hand vertically using a 1/2 inch extension bar. Air coming out of the cylinder through the sump and still see a 80psi drop to 20psi on leak-down gauge( in all positions of the piston TDC through BDC).
Note all other cylinders make a much lighter sound in to the sump. #6 has a great deal more hissing than the others. I assume its on its way out. The bubbling oil to be clear Geohorn, is when the engine is running if I remove the dipstick oil pushes its way up the filler tube and runs down the block. Not spurting, but bubbling as the air is pushing it up the tube (amount is a teaspoon or so every minute). if I take off the lower filler pipe it stops and the blow-by air is coming through there. Note that the tappet cover breather pipe screen needs cleaning, there is an amount of oil in the mesh. I can still blow through it with my mouth but if I remove or clean the mesh I imagine the dip stick would stop bubbling( it doesn't push the dipstick out only when I remove it). Its not overfilled with oil. My conclusion is the bad cylinder is causing most of the blow-by. I guess the unanswerable question is how long will it last? I can pull the head and then find that one cylinder is particularly bad, then it goes deeper in to the heart, remove the engine, , you own a M4500DT Geohorn so you would know its the biggest job and expensive! Where do you stop? Unless with that much blow-by its possible to nurse the engine along and it will last a while for all I want to use it for, which is slashing 5 acres a few times a year. Thanks again guys for your input. Look forward to further opinions.
3,296
1,709
Yes, Kubota sometimes asks for a Wet Test when checking compression, BUT you squirt a small amount of oil in each cylinder, then crank the engine using the starter 15 or 20 revolutions BEFORE you install the gauge and test the compression.
A couple of months ago on an SVL75-2, Kubota requested I spray Brake Clean in through the injector holes and crank it to clear it, then retest the compression. First time I have had that request.
Fishfarmer
Aug 8, 2021
114
I guess brake cleaner or if you meant brake fluid is less/non explosive. An oil change could be in order after using that. I put a some shellite in my bores and hand rotated it, so it would clean any oil marks off the cylinder walls, before looking with the borescope. I will be dropping the oil before turning the engine over.
3,296
1,709
It was Brake Cleaner, no oil change was required. R&R complete engine and it ran like a new one!!
KEO316
Kubota B7100
Oct 27, 2021
Colorado
I'm going through a similiar problem. A B7100, 2100 hours. Running good, slight blow by, but used almost no oil. Pulled it into the shed one day, came out 2 weeks later and it wouldn't fire a lick, nothing. Did a compression check, 2 cylinders were '0', fhe other was 89 lbs. (It wouldn't have even started or ran 2 weeks ago if it were that low). Oil in cylinder raised them to 80 lbs. Replaced head, valves, springs, injectors, all new gaskedts and still at '0'. Totally at a loss. A diesel mechanic friend said he didn't know how anything about pistons/rings could change so drastically just sitting in shed for two weeks. Weather has been above freezing the whole time. When we changed the head, the pistons and cylinder walls looked good, no marks of any kind. Pistons were smooth and shined up great when cleaned and had zero play or wobble in the cylinder. All lines have been vented properly and fuel is ejected out of the exhaust ports.
The glow plugs are heating up properly.
Why running good one day and then so sudden a chance in 2 weeks of sitting?
ANY IDEAS?
Fishfarmer
Aug 8, 2021
114
Others are more experienced than me but its unusual to get two pistons with zero compression unless there is something blown between them. I assume the pistons are side by side and the good one isn't the middle one? I did a leak-down test and it really helps to find where the compression leak is coming from, it can tell if the air is coming past the rings, valves or coolant, at least you can narrow that down. For you to have zero the air must be rushing through to somewhere. Do you know how to do the test? You need a workshop air compressor and can use your compression tester to do the test.
5,806
overall...it reads that #6 needs some rings, maybe oversize ? Or just replace sleeve,piston and rings as a 'kit' ? Assuming this engine does have sleeves.
Sounds like tractor is lightly used, so may be able to just toss the rings in... heck you've got 5.5 out of 6 cylinders running...that may be enough..
My Buda 4BD153 dieselled forklift needs all 4 sets done and of course the 'while it's out parts...' ballpark was $5K AFTER I pull engine and deliver. 1st step..remove 4000$ counterbalance..... Not happening... As long as it starts on 2.5 cyls, then 3 then the 4th kicks in, I can stay clean. When the time comes, I'll convert to gas for less than $1000.
Fishfarmer
Aug 8, 2021
114
Hey i would be happy to do that but I don't know if I mentioned in this thread I have an engine knock as well, maybe rings and rod bearing gone in #6. Bad rings I would put up with. 5.5 out of 6 is good, but if it becomes 5 out of 6 I don't think I am running and pulling a busted rod out. Like you tooo expensive to recondition it. From experience with cars if you have rod knock your time is limited before the rod goes throught the block. Maybe I risk to keep running until the noise gets louder and then look at replacing the one piston and bearing. I am hoping I can drop the sump on this without pulling the whole motor
