50 hour maintenance?
57plymouth
Kubota L3901 with FEL, 1955 Ford 900 Row Crop
Oct 26, 2020
41
15
Blythewood, SC
I have an L3901 HST that is on the cusp of 50 hours. I've read the owner's manual, and it appears that there is no scheduled maintenance until 100 hours. I've seen videos on YT about people changing all of the fluids and filters in their tractors at 50 hours.
Do I need to do anything other than watching my fluid levels? I grease the FEL every 10 hours and usually grease the tractor as well since I'm there. I torqued the lug nuts at 5, 10, and 15 hours and there was no change there. Should I just add that light bar to the ROPS and the solid sway bar links that I've been toying with adding and call it a day?
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
Look in the back on the maintenance schedule page. The first one is 50 hours. You change the oil, replace the hydraulic fluid and transmission filters, grease all fittings and torque the wheel lug nuts. There may be more but that is what I can remember off the top of my head.
7,377
Look down the 50 hour column of the maintenance schedule for the bulleted items.
57plymouth
Oct 26, 2020
41
15
Blythewood, SC
I see it now. Page 87 of the operator's manual. I was looking in the text which starts at 100 hours.
Thanks for the help!
bbxlr8
Mar 29, 2021
455
314
Eastern PA
I'm in the same boat now. Planning on oil change and filter + HST filter. Are there 2 hydraulic filters (1 for general & 1 for HST only or just 1)? Mine is HST
6,329
I had the dealer do my 50hr. Figured if they screwed up,they have to fix it.....besides it was hotter than Hades that week...something I can't cope with. I've done all the rest though, I just 'book all day' to do it.
Nicfin36
Jun 19, 2019
1,018
473
Decatur, AL
I changed my hydraulic fluid at 50 hours just because I wanted to replace it with Super UDT. It was probably a waste of money,. but I did it anyway.
SAR Tracker
Nov 17, 2020
256
390
Central Oregon
So I was looking in the Operators Manual for my LX2610HDSC tonight, specifically for width dimensions. What really popped out at me was just above that information (page 31) under "Capacities". Engine Crankcase (with filter) - 4.0 Liters (4.2 US Gals). WAIT..... WHAT? Not willing to believe my eyes, I went to the "Changing engine oil" section (page 124). Ahhhh.... more like it... - 4.0L (4.2 US QUARTS).
But now I wonder what else is wrong - Torque specs? Temperatures? Pressures? Clearance measurements?
Goz63
Jun 19, 2021
299
349
Mississippi
A US quart is similar but not the same as a liter. 4. 2 gallons. Now that’s funny.
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I have always used the Ford racing principal in regards to new engines (piston/ring engines). On my tractor I changed the engine oil and filter the first time at 1 hour, and then did everything at 50hrs. I picked it up with .4 hrs on it. I have followed the rest by the book.
I have done this with everything over the last 30 years. Cars, trucks, atv's, mowers, chainsaws etc.
7,368
I used to do the same. Motor oil change early, maybe 1,000 miles. Last couple have waivered, maybe 2,000 miles.
Current truck had GM "free" first service, at 7,500 miles. No thanks. I did take advantage, but I think it was 3rd....
OntheRidge
Nov 1, 2020
504
591
Yes, HST filter plus hyd filter
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
401
66
Wa
I will suggest changing ALL the fluids and filters, despite the manual stating otherwise.
I hated the whine from the HST and, while not eliminating it, it did diminish it quite a bit. Others have stated the same/
It really is not that bad, money or work wise.
4,266
That IS pitiful. Can’t fix spell-chick.
RailDawg
LX
Jul 3, 2021
Lovelock, NV
Guys I just did a 50-hour today on my LX3310.
Something weird though and I triple-checked everything. I removed the transmission filter and the hydraulic filter but the new ones would not screw on unless I swapped them. The hydraulic filter only screwed into the transmission and the transmission filter would only screw into the hydraulic.
Double-checked part numbers and everything. Is perhaps the manual mistaken? It must be my error but the two filters have different type ends for mating.
Thanks for the help.
Chuck
57plymouth
Oct 26, 2020
41
15
Blythewood, SC
Bought all the stuff today for the 50 hour service. I bought from the dealer since the tractor is still under warranty and I figured using Kubota parts may prevent an argument later if there were a warranty issue.
I wish they kissed me before they nailed me for $465 for the parts and fluid. Geesh.
Correction: $416. But still...
Goz63
Jun 19, 2021
299
349
Mississippi
Holy crap. My dealer will actually DO the 50 hour service for $300-350 Per quote. I have to get the oil yet and a little more trany fluid but will be less than $200 for everything For my diy.
7,368
Should have bought you dinner, then kissed you..... 🦞 😘
I'm just poking fun.
That said, I agree with getting Kubota parts from dealer.
SUDT2 fluid is likely a big part, but I can think maybe 6-7 gallons at $175 or so??!?!
I ask only because I staunchly agree that fluids and some filters be changed at 50.
I don't think air filters or fuel filters need changing at 50....
Your L3901 is much different than my little BX, but I think you might have some parts you can put on the shelf for next service......
If you don't mind, itemized, what did you get for $416?
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
I don’t know the tractor….
From parts diagram it appears the hydraulic filter is on the right side of the tractor (while sitting in seat facing forward) and the HST filter is on the left side of the tractor.
not sure if this helps any 🤷‍♂️
