BX2200 Axle Seal and Fuel Line help.
TnMowing
BX2200
Sep 12, 2021
24
11
East TN
I just saw this youtube vid pop up last night...replacing the front axle seal. It should cover exaclty what you have to do...
Thank you.
I did watch that video.
I got the parts yesterday.
I just need to find time to get it done.
Hoping the bearings are ok once I get in there.
TnMowing
BX2200
Sep 12, 2021
24
11
East TN
Can anyone tell me if this is right?
I need to replace the fan belt.
If I understand this right, I need remove the bolts to the front coupling.
-The shaft that goes from the engine to the HST.-
My manual says they are Torqued to 17-20 ft/lb.
Does this sound right? Seems low to me?
But I guess it doesn’t have a lot of torque on the shaft since it’s just turning the pump in the HST?
Would it be wise to use a little LocTite on them?
Any other tips when changing the belt?
It looks like it’s going to be tight working in there.
3,182
1,602
The torque is correct for the bolts in this application.
There is no need for loc-Tite, but if you insist, use a drop of blue on the bolt.
