L2501 engine oil.
Reynolds357
2501 L35
Sep 18, 2021
Georgia
What oil should I use? Kubota owners manual lists CF, CF-4, CG-4, CH-4, and CI-4. All of which are obsolete specs. Manual says can not use cj-4. Cj-4 is backwards compatible to the obsolete specs manual says use. Modern specs are back compatible to CJ-4.
I use Rotella T-6 in everything except my cat 988. Use T4 in it.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Don't over think it. T6 is fine.
6,932
Use T-6 in the tractor also.
I use 5w-40, and a lot of folks here do too. 15w-40 is good, but the 5w is better for cold starts.
6,932
Your 988 Cat?!?? What’s that take, a million gallons of motor oil?!?!🤔😎
Sometimes guys here will say a little kubota is not a 988…..You should know. Impressive machine.
Like I said before, T-6 is good.
Reynolds357
2501 L35
Sep 18, 2021
Georgia
I don't remember exactly how much it takes. I fill directly from 55 gallon drum. I think about 17 gallons. It takes a lot. It will pick up 48,000 lbs with the 10,000 lb counter weight on.
6,932
Holy smokes.....that's a big and great machine....impressive indeed. :p
