Loader running slow up and down.
je1279
Dec 6, 2020
828
585
Upstate NY
I'm having trouble with my L3830 Kubota tractor loader. load is running slow up and down but curling ok. What could it be?
Try to disconnect, clean and reconnect your raise and lower hoses and see if that fixes it. If not, try swapping the raise/lower hoses with the curl hoses. That should tell you if the issue is on the tractor side or the loader side.
2,857
what rpm? if increased - any effect?
Realdeal
L3830
Jun 3, 2021
9
North Carolina
I did the upper connections but will try the ones connected to the loader
je1279
Dec 6, 2020
828
585
Upstate NY
I would try swapping them and see if the raise/lower works normally when connected to the curl ports. Also check if the curl is slow when connected to the raise/lower ports.
Rollover Rudy
B2650
Feb 7, 2021
Northern Indiana
I had a similar issue with my B2650. Turns out my 3pt feedback was out of adjustment. Just throwing that out there, but I have no clue if your rig runs a similar hydro circuit.
7,007
I thinking that could be the problem. Did you adjustment it yourself? If so how did you do the adjustment.
Go here: http://kubotabooks.com/
I see the Workshop Manual (WSM) for the L30 series there (L3130-L5030). Should give you instructions on adjusting feedback rod. Should be pretty straightforward with the help of the WSM.
Rollover Rudy
B2650
Feb 7, 2021
Northern Indiana
On mine the rod was broken. I did the replacement and rough adjustment and had my dealer tweak it when it was in for an unrelated reason. You want to make sure the pump doesn’t dead head at top of travel.
