b21 adding skid steer flailmo
filterman
b21, bx1500, lx178 water cool,ransomes 36",jd 300
May 27, 2021
24
washington
mower to backhoe with separate pto pump. my pto output power 13hp. flow needed 20gpm to mower at about 2000psi. is there enough pto power to do this?
3,245
1,868
I'm not sure exactly what you're trying to do. Use a skid steer flail on the B21 loader with a PTO pump? In any case 20 GPM x 2000 PSI = about 25 HP, so no go. Also, how much does that mower weigh?
filterman
May 27, 2021
24
washington
Yes flail on bt751. Mower weight 250 lb or 500lb depending on model. Not sure dipper stick can handle bigger units cant find data on dipper pick strength. CORRECTION 30 LITERS PER MINUTE. So about 8 gpm.
3,245
1,868
BT851 is the backhoe. Are you wanting to put this on the front or back? I don't know anything about flail mowers, but if you're thinking about using this as a ditch mower, it sounds like a good way to turn your tractor over.
filterman
May 27, 2021
24
washington
Replace backhoe bucket. Hill mower. Bottom up. Will need tank, what size? 10 gal? Pto pump that fits, which one? hyd oil cooler? Dtent flow control or direct run only using pto? Pressure relief valve,which one? Hoses, which brand, pressures?
3,245
1,868
Can't help you there.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
120
47
SOMD
I had a B21 for 15 years and loved the machine. It’s very over built and capable but your asking too much out of it by trying to run a flail mower on the dipper stick. Hydraulic power pack hanging off the front loader for a counter weight and the needed hydraulic pressure...it might be doable, but for the cost you could buy a better suited machine and not tear the backhoe up on the B21.
