Shorten joystick throw
Spikeba
L3901
May 17, 2021
North San Diego County
Has anyone shortened the throw on your joystick?
I find mine (L3901) to be like shifting a 60's VW bus. Inordinately long.
I'm not talking skidsteer short, just not so far as to throw out my shoulder......
Spikeba
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
New tractor owner here, so take my comments with a grain of salt.....please.....but I saw a youtube video the other day of a guy on an old-ish, BX-something, who had cut down his joystick probably in half ! I liked it.
I don't know if I'd go that short (on a BX) but if I had what you had with the 60's V-Dub going on, the hacksaw wouldn't be long coming out. I'd probably save the chunk I cut off in case I had to weld it back on.
FWIW and good luck !
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
246
51
Southern IL
One of first mods I did on my 3301 was cut 2" off that stick. I felt like it was pointing right in my face.
Did same to 3pt lever too. My knee kept hitting it.
The trick to removing the knobs is to place a blow gun right on that little hole and hit with 90psi while pulling off.
5,257
1,043
As a child of the 60's and experienced in VW buses and cars, the shortened shifter needed a higher pivot point. This was accomplished by an extension of the base of the gear shift and a half ball of aluminum which slid over the shifter itself.
I have not seem anything similar for joysticks but cutting the shaft would achieve it. I would do it in steps so as to not go too far...... oops.
old and tired
L2800 HST; 2005; R4
I wish I could remember but it was either 6" or 8" that I cut off. Also the three point lever, I bent over to follow the contour of the fender. Allows me to exit to the right side (adding a step help with that).
The short handle does make it "touchy" and I can jerk the tractor around if I'm not careful. Figured if it didn't work, I could weld it back together....
cliffboyer
Nov 30, 2017
246
51
Southern IL
Spot on....wish I had done this instead. When turning torso to right in order to look behind, 3pt lever is now just barely reachable. A future mod to correct a mod is in order.
Jack@Northeast
LX2610HSDC
May 15, 2021
37
35
Natick, MA
I removed the OEM knob with the air trick ( thanks to Orange Talks! ) When I was test driving tractors the Kioti knobs were very nice. The Kubota shaft (model LX2610) is 13mm, the Kioti inside diameter is 12mm. I used a drill and reemed the Kioti knob and forced it on. But as stated in this string - the lever is to long. I will likely be cutting the shaft down a couple of inches. If that makes the control less sloppy then even better. I can't believe Kubota uses that tiny cheap knob on an almost 30K tractor. Isn't the loader knob the most used feature in the cab? Whoever approved the knob choice at Kubota should be fired, rehired and fired again!
Yooper
3901 LA525
May 31, 2015
1,641
785
NE Wisconsin
One of the best mods I did! I agree that the original just wasn't comfortable. Its been so long I can't remember how much I took off, but the bend makes a huge difference for me. I have a tubing bender so it was a piece of cake. I might have even replaced the whole joystick with a tube come to think of it. Posting this to help you with an option if nothing else.
5,290
Would you happen to have a PN for the control stick knob?
thirdroc17
185
35
I bent the lever on my BX in so it was 2-3" closer to me. Pushing it past the detent to bypass the $#*&$%( regeneration part of the valve was beyond my reach.
5,290
Where did you get that knob? Can you tell me who makes it and if they have a website.
See post #11. The link provided by Jack@Northeast will take you to an ebay listing. I ordered one from there this weekend.
5,290
installed....:mad:
MOTOROLANUT
Grand L4240, LA854 FEL
Apr 25, 2021
45
42
West Virginia
Do NOT buy from this Ebay seller. I did and they sent me a USED knob with cracks. The Ebay seller is a sham and tried to blame it on USPS. Obviously USPS did not put wear, silicon and stress cracks in the loader knob advertised as NEW. without packaging. Buy BEWARE big time. I am filing a complaint with Ebay. Sorry for the rant and no animosity to the op.
Jack@Northeast
LX2610HSDC
May 15, 2021
37
35
Natick, MA
Do NOT buy from this Ebay seller. I did and they sent me a USED knob with cracks. The Ebay seller is a shame and tried to blame it on USPS. Obviously USPS did not put wear, silicon and stress cracks in the loader knob advertised as NEW. without packaging. Buy BEWARE big time. I am filing a complaint with Ebay. Sorry for the rant and no animosity to the op.
Interesting - mine came in perfect condition and it even had the screw taped to the knob. I believe they were listed as factory take offs. But e-bay is the wild west and I don't have a lot of faith in the sellers.
Jack@Northeast
LX2610HSDC
May 15, 2021
37
35
Natick, MA
There is also a dealer Perry Power that sells new - they do not come with the securing screw and cost $ 30.00 vs $15.00 for the used.
