l60 sediment fuel filter.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
Just me, or has anyone else noticed the replacement sediment filter is a metallic strainer. The filter shipped with the machines are a cellulose pleat filter. I have used both on my transfer tanks and actually prefer the cellulose filters. I know they don't last as long, but I believe they trap contaminates better. I have not been able to find the oem replacement fiber/pleat filter in the parts listings.
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Just me, or has anyone else noticed the replacement sediment filter is a metallic strainer. The filter shipped with the machines are a cellulose pleat filter. I have used both on my transfer tanks and actually prefer the cellulose filters. I know they don't last as long, but I believe they trap contaminates better. I have not been able to find the oem replacement in the parts listings.
I think you are talking about the water separator? While it is possible a metallic screen would work, e.g. Mr Funnel, those have been treated with something to make them hydrophobic.
The part number I have on a paper copy I made from Messicks a few years ago is 1G311-43380 for an L3560HST.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
Your correct water separator, im too used to old machines. Look at the attached, below is the number you posted which is what I had as well. That is a metal mesh filter. The pleated filter below is a different part number. I just wondered why the listed replacement is metal and not the cellulose like they come shipped.
4,242
I’m not saying this is the situation in THIS case.... but often a part number is superseded to accommodate a service update or product improvement. If the paper filter proved to be an issue then a service letter or program might be developed to address that issue.... Perhaps a metal screen was found to improve performance, etc.... and the end-user may not be aware of the service letter/program.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
You may be on to something. The l01 series run a pleat filter in the separator. They do not have spin on fuel filters to my knowledge. The l60 is the only one that seems to have a replacement metal mesh separator filter. The l60 has a spin on fuel filter, so maybe a little less filtration by the separator doesn't matter. Both frames share CR-engines. So you would think they are picky on how clean the fuel is. Even more odd, is the l60 use a different separator than almost the entire l/m tractor lineup... It probably wouldn't bother me, if the new machines, and new separators didn't come with the pleat filter.
Seems I misspoke, the l2501 is different the larger l01's are the same water separator, so same filter. Still no spin on though.
