L355SS sometimes not moving forward.
David-in-OK
L355SS, brush hog, box blade
Aug 2, 2020
58
Oklahoma
Well I've been through all the major transmission problems with this tractor. Had a bad bearing on my clutch pack. That's fixed, in the tractor runs good. But sometimes I think I've always noticed this, I shift into gear and move forward on the shuttle shift and it doesn't move. Then I hit reverse and it's fine, then moving forward again and it runs fine now. Any thoughts?
2,443
1,257
If I recall correctly, your tractor has 2 clutches and a shuttle valve. I'd suspect a linkage adjustment. If not, something going on in the shuttle valve.
5,291
My guess is the Shuttle valve is either not seeing the right pressure or it's sticking.
