Slow Moving Vehicle sign for Snowblower
bird dogger
Vendor Member
Feb 24, 2019
1,758
1,736
North Dakota
Getting my snow blower rig ready for operation today I started thinking it would be wise to have a SMV sign mounted somewhere. Especially since I help take care of a few neighbor’s driveway that live nearby. And it’s getting harder to time the trip between driveways with the increased traffic on the roadway. At first it looked like the answer was to build a new mounting bracket for the SMV and attach it to the snow blower. Then I spotted the unused bracket on the backhoe and as the French would say, “Voila!” Or for the Norwegians amongst us, “Hoot Tee Too!” (although I’ve never been able to find the correct spelling for that phrase.)
One part was removed from the bracket. The “socket” part was reversed on the bracket as the bracket gets bolted on upside down on the back of the snow blower. One could even remove the socket part and just bolt the sign to the bracket with those same screws. But not knowing how much vibration there’ll be on the mounting, I chose to be able to remove the sign if need be and store it inside the cab. Then it can just be placed in the socket when traveling on the road.
To try it out first, a tywrap going through the SMV and around the bracket should keep it from vibrating out and getting chewed up in the blower. I’ll feel a little safer on the very short road trips between neighbors with both flashers and the SMV sign being visible. Come spring, it’s only one bolt to remove and a couple of minutes to put it back together for mounting on the backhoe or the rear of the tractor again. Things never go this well………there must be a gremlin hiding somewhere!
Here’s some pics:
Kubota SMV Bracket.jpg SMV Sign Mounting.jpg SMV sign on 3PT Snow Blower.jpg Tywrap Secured.jpg
UpNorthMI
May 12, 2020
849
567
Up North, MI
Here’s some pics:
View attachment 52219 View attachment 52220 View attachment 52221 View attachment 52222
Nice job, I’m like you I care about safety and being seen, not sure half the world does anymore, another great option is a flashing led zip tied to your rops, there are battery options available too.
doublebass73
L2501F, 68" Pull Type Snowblower, Spreader, Dirt Scoop
Oct 7, 2020
105
112
NH
I have a magnetic mount flashing LED that's battery powered, the batteries last all season. I just stick it to the ROPS. and it doesn't fall off.
bird dogger
Vendor Member
Feb 24, 2019
1,758
1,736
North Dakota
Same here. I stick this to the outside edge of my metal roof. It could be mounted inside for ease of turning On/Off, but then the side flashing LEDs get hidden by my cab corners. The batteries seem to last forever in these things and no worries of the magnets letting go.
You can see the wide back up mirror pretty clearly in the 1st pic. No need to look back over the shoulder except for safety reasons at the end of the driveway or working right next to a building. When pushing snow forward with the snow pusher the mirror keeps track of anyone coming up behind the tractor.
Bmyers
May 27, 2019
3,546
4,634
Southern Illinois
View attachment 52507 View attachment 52508
That looks like the one we use on my dad's MF383. It has held up well and we use it going to and from the north 40 acres, which is about a mile down the road.
4,014
2,705
If you drive on the roads PLEASE add some nice bright LED hazard lights and mount them high up on the ROPS too!
I almost rear ended a farmer last winter driving on the highway at night with heavy snow falling. I came upon him in the middle of an S bend, he had no lights, and his SMV sign was completely snow covered.
Bmyers
May 27, 2019
3,546
4,634
Southern Illinois
I just purchased a small LED warning light bar. I have to figure out how to mount it, but since we travel for about a mile on the road and drivers anymore can't seem to see tractors, I thought the extra lights would be worth the cost.
SidecarFlip
Banned
563
I use the battery powered LED flashers on my square bailer which has no warning lights, only implement I own that don't. Batteries last forever as was stated.
bird dogger
Vendor Member
Feb 24, 2019
1,758
1,736
North Dakota
They sure work slick, don't they? It's not worth the effort to run wires and install them permanently when you can slap on a magnetic flasher and be off and running in minutes. Let alone, move it from one rig to another as needed. Between the SMV sign, tractor flashers and this magnetic LED flasher mounted way up high, I feel pretty safe for the 1/4 mile trip down the paved road. But I still wait and try to time it so I don't have to meet or be passed by any other traffic of any kind. It's just not always possible.
SidecarFlip
Banned
563
I road a lot farther than that. I have 3 hayfields almost 30 minutes from the farm so I road a lot and other than my take apart rotary rake, all my pull behind implements are at least 10 feet wide folded up. Every trip is interesting.
