Replacing Halogen bulb with a LED in work lights on a L60 series cab
Garfield
L6060, KX033-4
Aug 27, 2020
Ontario, Canada
Hi, I'm relatively new to the forum and a new (to me) tractor owner. I have a L6060 and want brighter work lights on the front and rear of the cab. Instead of replacing the whole light, I just want to replace the halogen bulb with a LED bulb and see how it goes. I can always add a LED light bar if I need more.
I just tried to remove the clear plastic lens, but I don't want to force it too much. There's a small square hole in the middle bottom of the lens. I presume you put something small and push up and out? I just don't want to break the lens.
What is the bulb being used, so I can look on Amazon for a replacement?
Thanks,
Paul
Garfield
L6060, KX033-4
Aug 27, 2020
Ontario, Canada
Bmyers
May 27, 2019
3,500
4,452
Southern Illinois
No I don't, but I will be watching this thread and learning myself.
2,461
I think the bulb will be removed from the back. Probably a bulb holder into the headlight assembly to turn or somehow disconnect, pull out and bulb will come with it. Similar to newer vehicle headlights.
Edit= sorry for stupid post above. I didn’t realize you were talking about work lights and the comment was on headlights. I should read the thread title more carefully!
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
115
68
Traverse City, Michigan
Remove the housing from the cab and there are 2 screws in the back. (If its the same light as the b2650) the bulb from the link above is a h3 35w.
The thing that will be a pain is finding a led that is the equivalent lumans (or higher) as the 35w h3 and that fits in the housing. A 35w h3 has a lumen output of approximately 817 lumens.
I have been researching to try and find a replacement for my B2650 cab lights but havent found one that would be brighter (lumen wise) than the stock bulb. All the higher luman output bulbs require a heatsink and ballast and won't fit in the housing.
This is a direct replacement for the stock cab lights but is on the pricer side.
https://www.larsenlights.com/tl3240-led-work-light-for-kubota-tractors
Hey Michigankubota let me know if those work and are brighter than stock.
Garfield
L6060, KX033-4
Aug 27, 2020
Ontario, Canada
At $95 US per light, it is not cheap. I'll take a look tomorrow.
Thanks,
Paul
Garfield
L6060, KX033-4
Aug 27, 2020
Ontario, Canada
Hi Rcflyer330,
I took some pictures of my work lights. Do you think they are the same as yours on the B2450?
I see the two screws at the back. So if you take the work lights off, and unscrew the two screws, the front lens and reflector comes out and you can then replace the bulb?
I did a quick amazon.ca search and found these: https://www.amazon.ca/TUINCYN-Extre...&qid=1606321979&sprefix=h3+led,aps,220&sr=8-5
Paul
pokey1416
Jun 24, 2020
568
855
SW Michigan
Here’s another light replacement option, pricey though.
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
Installed my LEDs today, plug and play. Took about 5 minutes a light once removed.
Michigankubota
Oct 17, 2018
246
14
Hi Rcflyer330,
I did a quick amazon.ca search and found these: https://www.amazon.ca/TUINCYN-Extremely-Replacement-Daylight-12V-24V/dp/B075YHJQRN/ref=sr_1_5?crid=2FGDFS0JECKOU&dchild=1&keywords=h3+led+bulb&qid=1606321979&sprefix=h3+led,aps,220&sr=8-5
Paul
View attachment 51222 View attachment 51223 View attachment 51224
Yes those are the same as on my B2650
Michigankubota
Oct 17, 2018
246
14
they worked great. Plug and play. See my pictures in the above post.
Garfield
L6060, KX033-4
Aug 27, 2020
Ontario, Canada
Hi Michigankubota, thanks for the write up of your install. Yes, please let us know if the new LED bulb is brighter than stock.
Also, the stock bulb, did it only have one wire from it? I noticed your new LED bulb has two. The LED I found on Amazon.ca only has one. I want to make sure the one wire LED bulb will work too.
Thanks,
Paul
Rcflyer330
Oct 14, 2019
115
68
One or two wires should work. The negitive wire just goes through the body of the bulb if its a one wire bulb.
Michigankubota
Oct 17, 2018
246
14
Thats exactly what i thought but wanted to
The big question is How is the light output compared to stock?
Anytime you move from a Halogen to LED you will have improved lighting.
The LEDs made a nice improvement.
it’s like going from a 12v incandescent to a Halogen in the 80s
Michigankubota
Oct 17, 2018
246
14
Thanks,
Paul
Stock halogen has one power wire and is grounded through the body of the bulb. My LED has its own ground wire that I plugged next to the OEM ground. As stated above, one or two wires should work.
