Serial Number Breaks RC60-21B? Does anyone have a parts illustrated? Please.
5,140
938
I can help a bit from looking at Messicks parts info.
First, what I see is two different matched gear sets inside the gear box. The pair is identified as #080 which is my red circle.
Note the number of teeth on each set #080 which I have boxed in red.
On one model, the gears are 17 and 15 teeth, and after the serial number break the gears are 20 and 17 teeth.
Calculating the ratio between these two different gear sets I get 1.33 for the 17-15 and 1.17 for the 20--17
I assume the main pulley is slightly different diameter at the serial number break to correct the slight difference in gear ratio in order to produce the same blade speed.,
There are three complete gear box assemblies listed.
If the price does not shock you, then I suggest you call armed with your mower serial number. If you do not have the serial number, count the gear teeth to narrow down what you need.
rbargeron
Jul 6, 2015
1,151
220
western ma
Which piece(s) are needed?
KMoJo
B2150, G1900
Jan 18, 2020
24
Granger, Texas, United States
As mentioned above Messicks shows the parts diagrams. Or you can go to the Kubota Parts website.
I’m familiar with Messicks parts diagrams, the serial numbers breats are not listed. KubotaUSA has the parts breakdown for the B2150 but not the belly deck from what I can see.
KMoJo
B2150, G1900
Jan 18, 2020
24
Dang Dave, you really pick up on the detail. That’s awesome.
1,013
I did not look at your parts list directly but I do know that Kubota does break down the parts list with serial number breaks, usually in a column to the right with a less than and then the greater than symbol. They will have the same balloon number a couple of times and then you can see there may be different part numbers for different serial number series.
