54" VS 60" FEL Bucket
rAzkid
BX2200D, LX3310, FEL, MMM, PF, rear mount snowblower
Nov 6, 2020
87
36
MA
Ordered a LX3310 and the salesman asked if I wanted the 60" bucket rather then the 54" bucket. He said the 60" bucket is made from the same material as the 54" bucket but is called a light duty bucket because if you fully load it, the tractor might not be able to raise it. Did anyone else go with the 60" bucket and are you happy with it?
re54drider
L2800, FEL, Bush Hog
May 9, 2011
71
29
Goldston, nc
If it is wider than the tractor footprint then stick with the smaller one. I got convinced to go with the 60 inch bucket and I can't tell you how many times I have run into things with the wider bucket.
rAzkid
Nov 6, 2020
87
36
MA
With wheel spacers the tractor is about 57" wide so the bucket would only be about 1.5" wider on each side. Is that more then the width of your tractor?
SDT
multiple and various
Apr 15, 2018
3,376
1,161
SE, IN
I opted for the 60" bucket with my B3350.
No issues.
SDT
re54drider
May 9, 2011
71
29
Goldston, nc
Sorry, I misspoke. I have the 72 inch bucket rather than the 60 inch it is supposed to have. At any rate, if it is wider than the tractor keep that in mind when maneuvering around things.
MNVikingsGuy
LX3310, FEL, 60" bucket, 60" grapple, 60" box blade, 60" flail, LX2980 blower,
Sep 7, 2020
212
148
Minnesota
I have the same on order. With the wheel spacers and the R14 tires it ends up being 58"wide and I wanted the bucket to cover the full width of the tractor. My dealers said most do the same and they haven't had any complaints.
XrTweaked
L2501DT
Sep 23, 2020
Cincinnati
I just recently purchased a L2501 and it came with what was supposed to be a 60" bucket. The bucket's inside measurement is actually 65-1/4". I found that out when I went to order a Bxpanded piranha tooth bar. I love the bucket, wouldn't want anything less.
6,189
Get the 60". Your tractor will lift a full bucket of anything. There is no difference in build between the two, but the 60 will definitely hold more volume.
You can thank me later.
Edit: I assume that all LX models come with SSQA? Is that correct?
cjh
17
erie pennsylvania
Long story, but I have a 60" pin on and a 54" ssqa bucket for my 2650. You will appreciate the extra width of the 60 for sure. My 2650 has no issues with a full 60" bucket of gravel. It all comes down to ballast on the back and using your head when lifting things. I got the 60 to use from my dealer because the ssqa mount was on backorder earlier this year. I ordered the tractor with the quick attach 54, but due to the delays on everything, the dealer couldn't give me an answer as to when everything would be in. I used the 60 to move over 100 yards of topsoil and 35 yards of gravel. It had no issues. I ended up buying the 60 pin on for $250 from the dealer when all of the stuff finally came in to set up the quick attach. Now that the ssqa setup is on, I love the ease of changing between bucket and forks, but really miss the wider bucket. I can obviously still put on the 60, but I loose the quick attach feature. I was in a unique situation, but I did get to use both sizes back to back on the same machine and can give you actual real world feedback.
rAzkid
Nov 6, 2020
87
36
MA
Thanks for all of the replies. I went with the 60" bucket for no extra charge from the dealer.
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
I opted for the 54" and have wished I went with the 60" from day one. More volume would be nice. I've not found anything heavy enough yet that I couldn't easily lift a full bucket of.
nbryan
Jan 3, 2019
1,362
889
Hadashville, Manitoba, Canada
I went with the 54" ssqa when given the option mainly because one of the main jobs was, and still is, tight space maneuvering; more important than volume of bucket. Barn cleaning, forest and bush maneuvering, its been great. If sometimes I have to move volumes of material I also have the option of hooking up my 5x8 steel dumper trailer that can carry a lot of scoops from the loader. I like that the bucket is the same width as my tractor tires.
danmorea
kubota b7100 loader/backhoe Kubota B2650 loader John Deere x540
Oct 25, 2013
95
15
narrowsburg ny
Okay
I have a 60 inch on my b2650 that works fine
Now
If you look under the bucket mine has 2 wear plates
Other tractor that I have -different brands -has 4 wear plates under the bucket
Wonder if that makes it a light duty?
Not sure how many wear plates has the 54
PA452
B2650
55
Western PA
Okay
Now
I doubt it. I've always read and been told, as someone else stated, that they just call it light duty because they're implying if you were to load it all the way up with a heavy material, it may be too much for the tractor or cause stability issues.
That said, I've had my 60" "light duty" bucket on the B2650 filled to the brim with limestone and didn't have any issues. The backhoe is pretty substantial ballast though.
BobInSD
L5740
Jun 23, 2020
374
129
South Dakota
I agree with this. I put an 8 ft bucket on my (7' wide) 3020. I bumped into lots of stuff, and I would have been better served by the 7 foot bucket.
My initial thought was "bigger is better" and if I needed to dig a path through deep snow I could drive the tractor through the gap I cut.
