Looking for wider wheels for turf tires for B7100D
usuallyoutside
B7100D
Nov 1, 2020
New York
Looking to get a second set of wheels to mount wider turf tires for my B7100D. If anyone has a set they're no longer using, would be glad to take them off your hands. Thanks.
2,219
Do you have the rims moved to the widest point now? Last point on axle?
Your machine 4wd?
2,219
Yes, 4WD. The AG rims are currently at the widest stance.
So .... you realize that you will need to switch the fronts as well? The ratio needs to stay the same front/rear as it was with either set.
Does your machine have 4 bolt front end rims or 6 bolt pattern?
usuallyoutside
B7100D
Nov 1, 2020
New York
I do. I'm looking for a full set, front and rear. Hoping to find someone who switched from turf to ag and doesn't want their turf rims any longer, rather than buying new rims someplace. But also happy to take just the fronts or just the rears if somebody has a set of one or the other.
Thanks, should have mentioned -- 4 bolt pattern on the front.
kubotafreak
Sep 20, 2018
1,022
375
Arkansas, US
I have a set off a 29/15/12 rear and 20.5/8/10 front. Have rotted tires, and could stand to be painted.
kupitz
BX2660 with LA243 FEL and Front mount BX2750 snowblower/2763A heated Curtis cab.
Mar 28, 2016
130
New Providence, PA
I have two front rims, they are the newer 6 lug. I am in SE PA near Philly Baltimore.
Sorry - Just saw you need the 4 lug rims
