Under body muffler kit for M4900SU tractor
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
I am looking for an under-body muffler replacement kit for my M4900SU tractor. I am tired of the heat and noise from the exhaust that comes up right in front of the driver platform, so would like to move it to exit under the tractor. I know Kubota used to make a bolt-on kit, but can’t locate one. Any help is appreciated! Thanks!
SidecarFlip
Banned
562
Have it on my M9 open station (2002). When I took it in this last winter to have it brought up to 'snuff', I bought it used, my dealer remarked it was the first one he had ever seen but it was called the Kubota down exhaust and was an option. I even have the block off plate on the upper hood.
It takes an entirely different muffler. Exhaust exits right in front of the step off plate below the floorboard. I like it myself. Nice unobstructed view over the hood too.
2,431
Navy you looked at an illustrated parts list to see if you can identify the part numbers and see if you can buy them new? I have noticed that Kubota is pretty good about showing variations on different systems on my L185
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
Thanks for the info! I’ll dig around online and see if I can find a used one too.
e info
Thanks! Will look and see what I can come up with.
SDT
multiple and various
Apr 15, 2018
3,325
1,104
SE, IN
I have the so-called down exhaust kit on my M9960 to facilitate driving under trees without damage.
Not common and expensive.
Your dealer should be able to tell you if such is still available for your tractor if he decides to take the time to investigate.
SDT
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
SDT
I did find a supplier that would cobble together the pieces needed to move my muffler under my tractor. Expensive—north of a thousand bucks. I’ll keep looking.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
See attached Messicks p/l for under body exhaust. Call them or check with your local dealer to see if these parts are actually available.
BigG
Sep 14, 2018
1,951
774
West Central,FL
Do you have a muffler shop near by that could remove the old one and reuse the old parts to make you one? Maybe save you some money. I have a friend that likes to make the tubes. He looks at it as a challenge or puzzle.
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
That is an excellent idea! Several shops in the area—will check them out! Thanks!
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
Thanks for the info and diagram. My local Kubota dealer told me the “kit” was no longer available, but this would be a good start.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I turned my "stack" (tail pipe) 90 degrees so that the exhaust would exit to the side instead of toward the front. It made a huge difference.
Also as information, my John Deere has an under body exhaust system and even with the additional shield above the muffler, the heat will still melt the glue on my left boot and cause the sole to come loose.
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
Whatever I wind up doing, will make sure to have a good heat shield under the floorboard area—if I go that route. Turning the top stack is an easy thing to try. Will do that and see how it is. Thanks!
SidecarFlip
Banned
562
My open station came from a dairy operation. I assume it was used in the barns where overhead clearance can be an issue. On my cab tractor, the cab roof is higher than the vertical stack is. No issue with the hot exhaust pipe, it has a heat shield on it. The muffler on mine is different from the vertical muffler. The down pipe muffler has the inlet and outlet side by side. The vertical muffler has the inlet and outlet opposite each other.
Been kicking around removing the muffler entirely and going with a straight pipe. The turbo is actually a muffler. Besides, I like the sound of a straight piped turbo charged diesel engine. They make a sweet sound.
Removing the muffler from under the hood would reduce under hood heat as well.
