G5200 front wheel removal
Creemoretype
G5200
Dec 28, 2011
Creemore Ontario canada
Hi, newbe here so I apologise if this is old news. I have a flat on one of the front wheels of my G5200. Once I find a scewdriver small enough to remove the hose clamp agound the hub, what do I do next, will the hub just pull off or is ther more to it.
Thanks
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,190
171
Hardisty, Alberta
Thanks
Once you remove the cap ( held on with the hose clamp) you will find a cotter pi and washer, remove them and the wheel should come right off.
By the way, how are things in Creemore these days? I grew up near Redickville so I know your county well!
Ed
Creemoretype
G5200
Dec 28, 2011
Thanks Eserv, I will tackle it tommorw. Creemore and area is wintery but good. I drive or at least attempt to drive down 124 most days and on a bad day if I can make it Redickville
my chances of survivial are good.
Tooljunkie
May 13, 2014
4,150
35
A hammer.
Your favorite flavour of penetrating oil and a few whacks on wheel back and forth ot should come off. Check your bearings while its off, likely inexpensive.
A little polish on shaft before reassembly and next time it should come apart easier.
11,057
Have you already taken a hammer to the shaft? :confused:
If you have, you might have egged out the shaft and it will take some cleaning up of the shaft to make it round again to slip trough the bearing. ;)
BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
Ok, first of I am a complete newbie to this tractor as I inherited it with my house and I love it!
What am I missing, because the wheel will not come off!
Yes, at that point, it is supposed to just slide right off. However, yours may have some corrosion between the shaft and the spacer (spacer is between the bearings on the inside so you do not compress the bearings when you snug the nut.)
I would suggest soaking BOTH ENDS of the wheel/shaft interface with a rust-disolving spray (Liquid Wrench) and allow it to soak for several days. Re-apply a couple times a day and tap with hammer to set up vibrations to distribute the liquid.
When you are ready to attempt removal, place 2-by-4 long enough to touch rim on both sides on INSIDE and hammer against that. (attempting to force the wheel off the axle.)
BEWARE: The rust-disolving spray will contaminate the bearings. You will have to remove the bearings, degrease them and repack with grease.
ANOTHER OPTION: (which will not contaminate the bearings) Put the nut back on and reassemble what you have removed. Install tube into the wheel WHILE INSTALLED ON TRACTOR. (They do this on full-size tractors)
I assume you realize that castle-nut should be only finger-tight. NO MORE! Then install the cotter-pin. (loosen nut just enough to find an alignment with hole)
I was lucky with my G5200HST and the wheels slid right off. Then, I pulled on end of the tire off the rim and slid a tube in each one. No more flat tires.
NOTE: My G5200HST has grease-nipples on the front hubs. Your photo does not show this feature on your wheel. Infact, I do not even see the threads for the castle-nut. Does your wheel have ONLY a cotter-pin holding it on?
