is the D950 motor compatible to a D650 ??
451johnny
61
Stroudsburg
Hi everybody I have a B7001 Kubota with a D650 3 cylinder diesel 16hp motor that has to be replace and I have the chance to buy a D950 3 cylinder 19hp diesel motor that I was told is compatible to the D650 but I'm not sure ?? So my question is can a D950 be transplanted in to my B7001 Kubota which has a factory installed D650..?? thanks in advance ….johnny
8,772
Yes and no...
You will have to do some minor radiator revamping to make it work for a waterpump model.
You will have to add an alternator as there is no dynamo on the D950.
Check that the new engine has a pilot bearing in the crank.
Everything else will be a direct bolt up.
451johnny
61
Stroudsburg
….thank you so very much for confirming what I was once told ..I really appreciate it.....johnny
