m7060hdc losing power
carweld
m7060hdc,mx5200,g1800,g1800
Feb 17, 2019
sontag ms.
Been through fuel delivery system several times no restrictions in lines or filters .
when tractor cools of a little it runs fine till it gets warmed up again.
Any advice appreciated before going to dealer
SidecarFlip
Banned
561
Pretty sure it will be an electronic issue or emissions issue. Take it in and let them diagnose it.
carweld
Feb 17, 2019
sontag ms.
Will do ,Thanks just checking to see if anyone else had similar issues Local dealer want touch it for two to three weeks Going to look for another dealer Monday
Like Tractors
Several Kubotas
Jan 1, 2020
85
109
Eastern Iowa
The symptoms you mention sound remarkably familiar. I have been thru this from symptom to troubleshooting and testing. It's a long story if it is the same issue that I had. Contact me privately if you like.
carweld
Feb 17, 2019
sontag ms.
Tried to message you not sure if you got it but mine only starts missing and losing power after i have run it under a load for about an hour i can shut it down and let it cool for a few minutes and then its fine til it works for about an hour again
Like Tractors
Several Kubotas
Jan 1, 2020
85
109
Eastern Iowa
I got your private message, I responded with a phone number for you to contact me. The symptom that mine had was low power after running under load for an hour with a misfire. I test common rail Diesel engines for a living, that gives me an advantage when it comes to finding the cause of the problem.
JerryMT
Jun 17, 2017
529
153
The Palouse - North Idaho
Problems running when engine is warmed up. If you are sure it's not a problem with blockage in th fuel delivery system and you have a hydromechanical injector pump (IP) than it sounds like the IP will need to be rebuilt.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,257
161
Coyote Flats,Texas
Have you checked to be sure fuel tank is venting? Try operating engine after symptoms appear with fuel cap replaced by a shop towel. I once owned a M4900 that acted similar to your tractor. From advice from local dealer service manager I located a clogged tiny screen in water seperater fuel shut off valve. Cleaned screen & lack of fuel problem was solved
carweld
Feb 17, 2019
sontag ms.
Appreciate all responses still checking all options till i can get it to dealer. Again thanks i will post solution soon hopefully
