2018 L3560 steering wheel center cap
NWAZL3560
L3560, LA805 loader, BH77 backhoe, rock bucket, box blade, pallet forks
Jun 11, 2018
127
55
Mesquite, NV
My steering wheel center cap popped off when I was doing loader work in 4wd the other day. The largest of the three tines on the cap is broken. I don't believe my L3560 has a horn, there's no horn symbol on the cap.
Is there any issue with just tapping the cap back in, like could the broken tab piece be interfering with something below the steering wheel?
If I got a new cap like I'd be entitled to under warranty, the steering wheel would have to be removed to install it. I'd have to pay the Dealer to come out or haul it in to do that, not sure it's worth that.
Daveinwestmi
L3560 ROPS, BX2380
Jul 6, 2019
12
Kalamazoo, MI
Same thing happened on my l3560 except the cap was lost. Just bought a new cap and popped it on, no need to remove the steering wheel.
Sent from my SM-G960U using Tapatalk
SidecarFlip
Banned
548
If you cannot afford the cap (10 bucks), I'm flabbergasted and I don't believe Kubota would cover it though your dealer might as a goodwill gesture.
Daveinwestmi
L3560 ROPS, BX2380
Jul 6, 2019
12
Kalamazoo, MI
Kubota learned there parts pricing from Mercedes, that scrap of plastic is 23.78. The third function switch on a b2650 is $170, its a switch you can buy from a good electrical supply house for $30 and a 3 foot harness.
Sent from my SM-T350 using Tapatalk
SidecarFlip
Banned
548
So, don't replace it. Just leave the nut to look at....:eek:
4,414
Flip, you obviously have not priced them!
Take the cap up off the slots, put a touch of black rubber adhesive around the outside edge and set in back in place.
SidecarFlip
Banned
548
You are correct, I did not. I assumed (wrongly I guess) that a blow moulded plastic part wouldn't cost that much, obviously I was wrong, but then the main shift boot (a small black rubber boot) was cheap and it was 27 bucks with no clamps, just the boot. Kubota OEM parts are all over the place in prices. Some you can pick up aftermarket, some you cannot. Like tie rod ends for my M's. Kubota OEM are 175 bucks each, aftermarket are 50. Needless to say, I went aftermarket and don't ask how much the inner radial joint costs OEM because that is scary.
Should be able to find that bezel online aftermarket or at a salvage place.
NWAZL3560
Jun 11, 2018
127
55
Mesquite, NV
I just re-installed the one that came out even though one of the tines had broken off. Tapped it in with a rubber mallet. The problem with putting in a new one is that I didn't find the broken part of the tine, and it might still be in the steering wheel.
4,414
With one tine off and no adhesive, it will come up missing one of these days!! Especially if you haul it on a trailer.
SDT
multiple and various
Apr 15, 2018
3,084
926
SE, IN
Bingo.
I "glued" mine back on with black RTV.
SDT
SDT
Apr 15, 2018
3,084
926
SE, IN
Same thing happened to my L6060.
Dealer gave me a new one under warranty and I found the "lost" one about a month later so I now have a spare.
I sealed mine back on with black RTV.
SDT
3,045
Ahhh-Soo! Noble-Mastel say this fol what Hot Grue Gun invented!
NWAZL3560
Jun 11, 2018
127
55
Mesquite, NV
You're right as others have said too. I can see it loosening every time I use it. I just tap it down occasionally. I don't trailer it. I don't want to adhesive it and have to deal with that if the steering wheel needs to be removed some day, my choice.
