BX1870 won't move
ChuchVT
35
Johnson
I went out to plow this morning and I made two passes down my driveway and when I tried to back up it was very slow. It was also slower than normal going forward.
When I got back to the top of the driveway I couldn't go in reverse at all and I could hardly move forward. I moved the gear selector from high to neutral to low and back several times and I engaged and disengaged the 4WD several times as well and nothing seemed to help.
I've checked the hydraulic fluid levels and they seem fine. The treadle peddle doesn't have much resistance when I move it.
Any thoughts would be appreciated.
4,118
any chance pedal linkage is disconnected from the HST unit ?
I know nothing about the 1870 but some nuts fall off others so rod isn't connected.
200mph
Mar 3, 2017
1,228
60
PA
Many folks are using self-locking nuts to prevent this from happening again.
Glad it was something simple.
dlsmith
BX2230, LA211
Nov 15, 2018
1,198
715
Goshen, IN
This seems to be a frequently recurring theme here.
Sounds like an item to put on the engine oil or hydraulic oil change checklist.
