B2650/3350 Cab Rear Wiper Replacement
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
115
68
Traverse City, Michigan
Has anybody replaced the rear wiper blade on their B2650 or B3350 cab model?
I have been searching and searching but can't find any information on a size or part number except the entire arm for ~$80. I have tried to remove it but it doesn't want to come off and I do not want to break it.
Thanks in advance
200mph
Mar 3, 2017
1,228
65
PA
Can you post a few clear pictures of the blade/arm interface for a few different angles?
There are only so many ways wiper blades attach to the arms, but it's always possible Kubota came up with a better idea.:eek:
Is there any chance the rubber insert can be changed? This use to be a popular method, but has lost favor over the last 10-15 years.
My Grand L cab uses the common j-hook, but that is of no value to you.
Rcflyer330
Oct 14, 2019
115
68
Thanks I will try to get some pics later tonight. I will say It's not a standard j style wiper arm it's completely plastic.
If I can't find a replacement i will just change the rubber part.
Sent from my SM-N950U using Tapatalk
7,029
I don’t have any answers other than a wiper issue came up a few weeks ago.
Don’t recall anything specific about it, but wanted to mention while I thought of it.
Didn’t have time to research it right now, but if it helps the OP, that’s great!
Rcflyer330
Oct 14, 2019
115
68
Okay, while I was taking pictures I figured out how to remove the rear wiper.
To remove the rear wiper blade you need to pull the blade half under the arm past its angle stop. After that it comes right out.
Pic 1 is the assembly.
Pic 2 is the arm end with the wiper removed.
Pic 3 is the blade at the angle it needs to be at to remove it.
Pic 4 is the blade removed.
Funny thing is I looked at the assembly mulitple times before I decided to create a post. But for some reason while taking the pics I tried one more time and figured it out. Hopefully this post can help someone else out.
When or if I find a replacement I will post the brand and model number for reference.
Thanks for the help.
200mph
Mar 3, 2017
1,228
65
PA
Great description and photos! I'm certain other B2650/B3350 cab owners will find this helpful as their blades wear out.
You'll have to post back the blade # that will work with this mount. With any luck any correct length replacement blade will work with one of the many adapters that seem to come with them these days.
I can't help but think the lack of PN or callout in the parts diagram is not intentional to maximize profits and screw the customer. I'm all for them making a profit, but there are times when companies seem to be taking advantage of their customers.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
That's the same design as an Asian SUV (Rogue / RAV4 / Pilot) rear wiper. Post a length and I can probably get you a part number.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,495
518
I was going to say...that kinda looks like what is on the rear window of my VW Tiguan?
I have never had it off though so not sure if it is the same.
Rcflyer330
Oct 14, 2019
115
68
Length is 12"
Looking at some picture online the Toyota RAV4 looks to be the closest one. It makes sense too being Kubota and Toyota are both Japanese companies.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Probably...." Maybe" is closer.
There are now 5 Roc-Lock designs ..... there used to be 2. Definitely take the old one when you go.
Trico numbers are:
12-A <<< I believe this is the one
12-B
12-F
12-J
12-K
Rcflyer330
Oct 14, 2019
115
68
Here is what fits... I tried a trico rear 12" 55-121 using adapter A and it works fine.
Pau7220 got it right with the 12-A blade that is the exact replacement size.
TimP
B3000
Jan 16, 2012
64
Baltimore, MD. USA
I don't have a B2650 or B3350 but I do have a B3000.
I have replaced the rear wiper blade and I used this replacement blade and it works very well.
https://www.amazon.com/gp/product/B000XH82O6/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
I think the cabs are pretty similar to mine so maybe that can work for you also.
Hi War Eagle. I also have the B3000 and need to replace my wiper blades.
The dealer wanted $25.00 EACH for the Blades.
So I'll try my luck with the ones you show from Amazon. ($13/each)
I measure the Front blade at 16" and the rear blade at 12". Does that seem correct?
How hard is it to remove the old one?
Thanks !
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
102
21
Nampa, Idaho
TimP
I went out and measured my blades and the front one is pretty close to 17 inches and the rear is 12 inches.
Both the replacement blades have been working fine and they have been in place for 2+ years now.
The replacement blades have the J hook shape and they were not hard to replace. As I remember the new blades came with a small piece of paper showing how to install.
Good luck
Earl II
2021 LX2610
Jan 1, 2022
11
9
Idaho
I read this thread looking for a replacement rear wiper blade for my cab model LX2610. Looked online and the Kubota parts source wanted $34. Saw the Trico reference so went to O'Reilly's Auto Parts and found an exact replacement 12". It is the Bosch Spectrum Exact Fit 12" #R1216. About $14.
