Digital Tachometer
rbeall
B8200
Mar 30, 2018
25
Sault Ste. Marie, Ontario
Good morning all, since my B8200 HST has an alternator and not a generator I no longer have a tach. I purchased a digital tachometer and a proximity hall sensor.
https://www.amazon.ca/ELING-Universal-Digital-Tachometer-Backlight/dp/B0755JF9FK
https://www.amazon.ca/Yosoo-NJK-5002C-Proximity-3-Wires-Normally/dp/B01LX0J9H4
I have installed the proximity sensor that take a reading off the engine front crank pully. With all the wiring connected I turned on the ignition and the tachometer lights up with all 8’s then goes to 0 RPM and 0.0 hours. Then start the engine and the RPM stays at 0. I attempted to follow the instructions for adjusting the tachometer readings by pressing the button on the back, went through all the settings in increments of 50 from 1-300. No change, 0 RPM.
The proximity sensor was bench tested and once the engine is running the led on the back of the proximity sensor is on.
Any ideas of how to test the tachometer on the bench?
200mph
Mar 3, 2017
1,228
65
PA
What are you using to trip the proximity sensor?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
I don't think the sensor will sense any change in the rotation of the crankshaft pulley. I think you have to attach a small magnet. It then senses each time the magnet passes the switch. If that's the case you could test on the bench with an electric drill spinning.
William1
BX25D
Jul 28, 2015
1,238
438
Richmond, Virginia
Yup a tiny disc magnet or even just a blob of metal that will cause a change in the magnetic field. In some cases, a notch works too.
rbeall
B8200
Mar 30, 2018
25
You guys are correct about a magnet. I had installed a magnet glued to the pulley at the correct distance from the proximity sensor prior to the original post. I have now also noticed the hour meter internal to the gauge is also not counting. I am good no to try and contact the seller to find out if the gauge is just faulty.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
Your gauge may be faulty. The pickup could be defective. A third option is the possibility the wires are connected incorrectly - either by you or internally in the sensor. Whatever the reason, Amazon is really good about exchanges and refunds.
2,293
There is a company called TinyTach that has a tachometer that reads off the injector pump pulses, if what you now have doesn’t work out.
rbeall
B8200
Mar 30, 2018
25
An update.
After a couple of emails with the seller of this tachometer, I got enough information to hook it up properly. I asked what type of sensor is required for this tachometer and learned that it needs an AC signal to work. The proximity sensor that I tried supplies a square wave DC signal, so it wouldn’t work. So, to get the proper signal YouTube was my friend. The “W” tap off my alternator was not there. I opened up my alternator and connected a wire to one of the coil ends before the diodes and bingo, a working tachometer.
This was really easy to do after having enough information to actually connect it up.
5,257
1,046
Thanks for the update.
How are you linking the alternator signal to the actual engine rpm?
The alternator will be turning faster than the engine.
rbeall
B8200
Mar 30, 2018
25
The tachometer has a setting button on the back that I needed to adjust. The instructions said to set the tachometer to the number of poles in the alternator. Once the idle speed displayed was between 600-800RPM, I was at the correct setting. Full factory throttle displays 2700RPM.
