BL4590 Boom Swing Cylinder leak. Are Seals easy?
countryguy
L2550/FEL/BH M6060/FEL ++
Nov 23, 2018
38
Fenton
Soooouuuuuu.... Just when I was about caught up w/ mech-madness around here; the BL4590 backhoe on the L2550GST has a sudden boom Cyl leak. Right side, when in seat. Right around the shaft/seal area. Nothing to crazy yet but needs to get resolved. I attached the image from the parts site. The Boom Cyl seals show a #16 and a #17... (see image).
Anyone know how hard a project this would be as a DIY item? Plenty of skill w/ everything but Cylinders. Anyone know if I need to replace both 16 and 17? any specialized tools needed?
Finally, would this just be easier to pull and take to a Cyl rebuild location.
TIA!
https://www.messicks.com/ku/84696
image attached of Boom Cyl .
5,133
TIA!
you need more than just the 2 seals, you need the whole seal kit to do it right.
I think they are easy to work on, but I think most things are easy.
No real special tools to do these type of cylinders because they just unbolt to take them apart. ;)
countryguy
Nov 23, 2018
38
Fenton
OKy doky.. could not find a BL4590 OPs/parts manual, but I did find the one here. It looks nearly ident! Its for the 4672/4690.... Should suffice for assy/dis-assy ref once I get it all into the shop.
Now, anyone know what the difference is from a 4590 to a 4690 BL? Curious on that one....
tip: The seals kit is #19 on the kubota parts side so folks know. Not 16/17 but 19 for the full kit. Thanks for the reply on that Sir!
For the work ahead : would anyone also happen to know if I will need to pull the boom off to get the Cyl out and do this right? honestly guessing because I have not looked at it yet as it's at Brothers place. sooo.. this means I fix it out there if NO and bring home if the booms coming off w/ the overhead gantry platform. Just thought I'd ask. Newb on a cyl. repair. Always wanted to crack one. times up!
countryguy
Nov 23, 2018
38
Fenton
Wolfman.... 18.5K posts here! Wow... in Canine-lupine post-years that is like 130,000 :D
