New Kubota L2501 ordered
TiftTyson
2018 L2501 HST, LA 525 Loader, Landpride Rotary Cutter, Box Blades;Bush Hog Til
Mar 24, 2018
19
ATHENS, GA
I would stick with a 5 foot rotary cutter. I can speak from experience that a L 2501 will handle it well. You may have to slow down in really thick grass or tall brush, but it will chop it all up well. I have the LP 1860 (mid grade ) rotary cutter.
I mowed my neighbors field with the LP 1860 with Johnson grass almost hood height. My L2501 performed well. I was paid back with a strawberry ice cream pie. Took a week to eat it. Pretty good deal for me!
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
217
11
Ted,
Thanks for posting the chart. I notice they don't recommend the RCR1860 for my L2501 but that's what I purchased with it. It is only 121 pounds heavier than the RCR1260 but I have no problem running it. Looking in the RCR1860/1872 Owner Manual My L2501 is certainly within spec to run that cutter. I wonder if the chart is a guide for the dealer to use to bump customers up the the L3301 or L3901. My dealer likes the L2501 pointing out that it is the most sold compact tractor in Texas of any brand.
I would like to see a Youtuber do some comparison testing with the standard L series tractors to see what the real world difference is.
PaulL
B2601, MX5200.
Jul 17, 2017
2,805
1,794
NZ
No reason not to run a 6 foot cutter if you're mowing high and what you're cutting is thin. It'll bog if you try to run it at ground level on thick grass, but sounds like that's not your intention.
You could run a larger flail mower, which would cut down your mowing time. Because the flail sticks out a lot less behind the tractor you can lift more weight, and because a flail is lighter you can run a bigger one. I think a 72 inch flail would be OK - i.e. 6 foot. And a flail can also be used to mow your lawn.
For what you describe you have no real need of a rotary cutter.
ken erickson
Nov 21, 2010
1,440
2,674
Waupaca Wisconsin
Paul,
My one concern with a flail mower would be cutting at the 8 to 10 inch height. Are flail mowers designed to be suspended off the ground while mowing or are they normally run with the skids having ground contact?
ken erickson
Nov 21, 2010
1,440
2,674
Waupaca Wisconsin
This picture shows a maintenance mowing on 5 acres that was seeded this June.
The seeding included about 25 different native wild flowers and 5 native grasses.
As you might be able to tell the brush cutter is set to about 6 to 7 inches for this session. Just cutting the tops off of weeds before they can mature and go to seed. But this gives you an idea of the light cutting that will be involved on the complete 28 acres starting next summer.
Cathy Liebchen
KUBOTA M7060, MX5800, MULE PRO FX, MULE PRO FXT
the L2501 does not have enough PTO horsepower to run a 6 foot mower. Need at least 30 HP (5 per mower foot). Underpowered mower is a pain in the ass- we learned this trying to run a 5 foot mower behind a L2501. And definitely go with the 18 series mower from Land Pride, the 12 is light duty
ken erickson
Nov 21, 2010
1,440
2,674
Waupaca Wisconsin
Thanks for your input Cathy!
Did you feel you were underpowered with the L2501 and the 5 foot cutter?
A few more pictures of my B7100 , 13 pto hp , with 4 foot cutter in thick goldenrod and grasses. Cut well but of course slowed the travel speed way down.
nota4re
Case 580M Turbo; Kioti DK4210SE-CH; Kubota L2501 (Traded-in)
Aug 16, 2019
129
46
Newhall, CA
I am a new L2501 owner and also purchased the 1860 rotary mower although I really haven't used it much. When I was shopping, I asked the (large) dealer why he packaged in the 1860 instead of the 1260 (and maybe save me a bit of $). He said the 1860 was pretty much all they used across all of the L-series tractors and the dang things are about bullet-proof. He had nothing bad to say about the 1260 but he knew from experience the 1860 was super reliable. I was happy with his answer and on top of that his package price was lower than others that had included the 1260. Win-win.
PaulL
B2601, MX5200.
Jul 17, 2017
2,805
1,794
NZ
Paul,
I think you can run with them raised, position control will help with that.
A lot of people saying that you should run a 4 foot or 5 foot mower. They're strictly correct, if you're mowing at ground height and thick material. If you're mowing above the growing native plants, then you'll be mowing very high, and it'll naturally be quite thin. I think really in that scenario you can run as big a mower as the tractor can lift.
You might also think about use for the mower after the natives have grown. If you buy a large mower now to save a bit of time 2-3 times a year for 2 years, then it'll be too big for other use ongoing. So you'll need to sell it and replace with a properly sized mower. Or, you could get a smaller mower now, and be a bit slower on those first few mows while the property is establishing.
I'd also say that mowers hold their value pretty well. If what you buy is wrong, then trade it on a different one. Also, you can probably borrow one from someone near you to see if it works well (or maybe even from the dealer if they have a second hand one in stock that they don't mind you mowing once with to see if it works right).
Missouribound
Jun 17, 2014
668
62
Missouri
Paul,
Do you know how heavy the mower is? Lifting the mower is one thing, but balancing it is the other. My finish mower can easily lift the front wheels off the ground if I lift it too aggressively.
