Orange zero turns
Missouribound
Jun 17, 2014
657
54
Missouri
I am looking to replace my lawn tractor this year or next spring.
I have been looking at the Cub Cadet Ultima but the Kubota Z100 series seems well made. I do not need a commercial type mower, being used just on my yard.
The thing is I would like to keep it around $4000.
Anyone have any experience with Kubota's machines?
I am not stuck with Kubota or Cub by any means but I am in close proximity to both dealers and already have a good working relationship with both.
Any advice will be appreciated.
6,623
Missouribound, I can't help you at all. Mine is beige and brown. But it does have a Kubota engine!
Maybe Daren Todd will show up. He can give you some pointers.
KennysNewFarm
MX5800
Dec 28, 2017
220
Missouri
Our Kubota dealer in Smithville carries many brands of zero turns. Exmark, Scag, Kubota etc. maybe if your not too far away you can take a look at all the options. I have owned an Exmark for the last 11 years and it has been very reliable, durable, and efficient. I would recommend two things on your purchase two hydro stats one for each wheel and a commercial grade deck. Other than that it is all about size and HP. I tried the adjustable tension seat on the higher priced tractors and they do not really work to me. Mine is a 24 HP 52” cut and roughly runs four hours on 4.5 gallons of fuel.
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
^^ he is giving you good unbiased info. important points if you are a serious grass mower.
on big zero's: you need separate wheel motors & pumps & then different power for the deck.
floating/suspensions seats help: but zero's just dont have a great ride. they are made to cut lots of grass really quickly... but not plush rides.
Kubota makes a real good zero turn mower. the big diesel is a great engine & p erforms awesome.
the ONLY drawback on Kubota zero's was that if you lost a wheel motor/pump you had NO BRAKES!!
Hustlers, excells & most other brands have now went to putting mechanical drum brakes on the wheels so that you dont wind up hitting a tree head on like my father did when his right side wheel motor went on on the big Kubota Zero.
just dont by one of those little lightweight zero's if you plan on mowing huge fields. it wont last.
put 2500 hours on my Hustler ATZ before selling it & have almost 2,000hrs on my Super Z HD now.... they are awesome for mowing big yards.
3,185
1,604
What model of zero-turn does your father have? Is it a ZD or Z series because all ZD series have the brake in the final drive housing.
mickeyd
Mar 21, 2014
1,192
Guin, AL
My Z121S is a great machine. It has the Air-Ride seat and a commercial deck.
3,878
2,522
I have a bias against CC as every machine I have encountered seems like its designed to self destruct prematurely. My theory is if you can buy the machine at a big box store Id avoid it like the plague. Unfortunately I went with a commercial ZD326 and its been bulletproof for the past 10 years.
Mowers can take a lot of abuse and can have a lot of vibration. If you are cutting acreage Id look for as HD as possible, and have the salesperson demonstrate each machine how to raise the deck to clean the bottom of it and sharpen your blades. And get the most comfortable suspension seat you can.
sdk1968
Oct 19, 2016
929
44
not sure. the churches insurance totaled it.
it was the big diesel. fantastic mowing machine. climbed well too! plenty of torque.... just was a sled once you headed downhill & then when it went out it was a "speed sled" LOL
on flat ground or easy terrain it was an absolute grass eating machine.
(footnote: they went to a STIENER/Ventrac now)
m.t.hands
L 5030, L 3400 and BX2200
Jul 26, 2015
137
NE Bama
lmao...... maybe you just got a nice yard? :D
like a guy told me his would mow at X MPH, I said no it won't :rolleyes:, he informed me that in the manual it even states the performance, I told him go ahead and try to cut your place or about 99.9% of the other properties you'll be caring for at WOT travel speed and get back with me;), maybe a golf course
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
I broke my back years ago and with my bumpy yard I'd either have to mow painfully slow, or mow at a normal pace and be in pain. I looked at every mower I could find and the Ferris was the only one with full suspension. It really does a great job of letting me mow at a fast pace without beating me up. What used to take me 4.5-5 hours now takes me only 1.5 hours and my back doesn't hurt after. At first I thought the suspension was a gimmick but for me it was well worth the extra $$. And no, I don't work for Ferris, just a super satisfied customer.
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
The Exmark I test rode was probably one of the best put together machines I tried and cut as good or better than anything else, but the suspension on the ferris won out in the end for my back. And, sorry for the thread jack.
sdk1968
Oct 19, 2016
929
44
FH,
thats not a thread jack. its good quality info that will help the OP in making a decision.
like you guys said: the beast im riding will mow at 16mph & yes if you had a drag strip that needed mowing? it will.
try going thru my rough yard at even a steady 10mph & you will look like you are riding the mech bull down at the bar.
sure there are spots where you can hit top speed, but there are other spots where your are doing maybe 4-5pmph & just gritting your teeth.
that floating suspension sounds VERY nice! If this old girl ever gives up the ghost? i'll be looking into it for sure!
although gotta admit im really diggin that new ALTOZ:
https://www.youtube.com/watch?v=-CTHoxmOeL4
man00
197
12
okla
I don't think there much difference between any of them (brands). When comparing residential to residential or commercial to commercial. Other than $$$
