Adding power steering l2250
5,129
That tractor came with PS, so no, no one makes a kit to do it.
You would have to change the Hydraulic pump, various plumbing, and a PS gearbox and parts to turn it into a PS tractor.
That's going to be a tall and expensive order to fill.
You could also give it hydrostatic steering (hydraulic controller and a hydraulic steering ram, but then again you would have to source and fabricate all your own parts.
Find another tractor with PS and sell that one. ;)
5,129
Check your private messages.
There might be a guy who makes ps kits
Dave have you looked at the layout of his steering?
It's not a setup that normal add on Power Steering will work on because the steering box is under the front center of the tractor. ;)
5,128
933
What I saw in pictures of from this guy was a true hydrostatic setup with new steering column & hydraulic valve + hydraulic cylinder.
The existing box would be gone.
As you said: " You could also give it hydrostatic steering (hydraulic controller and a hydraulic steering ram, but then again you would have to source and fabricate all your own parts."
I do not know if it is available still and further if it would work on this tractor
